Hi all,
I have a problem with SNMP V3 on Cisco 3750 series switch, i did the SNMP Configuration on switch after that
I tried to add the switch to our solarwinds server (the group was AMTSNMP as show in config),but no luck (solarwinds shows the message test failed)
I am using separate VRF (MGMT) for the management purpose and i am able to reach solarwinds server from that VRF also.
i have attached my config for the reference,
does any can help me on this, thanks in advance.
