Cisco 3750X Switch with C3KX-NM-10G
metuckness
I have a switch stack that has 4 3750X switches and three of them have the SFP module C3KX-NM-10G. Which two ports are the 10GB ports and which two are the 1GB ports?
I have tried to figure them out, but so far no luck.
There are 4 ports,1-2-3-4, and they are labeled G1, G2/TE1, G3, G4/TE1.
I have SFP+ 10GB Fiber modules to put in, but I can't figure out which two ports are the 10GB.
I found a table, but frankly I can't read it.
Table 4. 10GbE Network Module Configuration
Interface Options
Network Module
10GbE SFP+ Ports
GbE SFP Ports
1GbE
10GB-T
2 (RJ-45)
Service Module
is it ports 1,2 or 2,4 or 1,3?
I appreciate the help.
Hi there,
In simple term, you need to have SFP+ to have two tengig interface. you can connect two SFP+ to any port out of four physical port .
But  cant have more than two tengig at any time. If you connect SFP then port will act as 1 gig interface if you connect SFP+ then you can configure that port as 10 gig port.
C3KX-NM-10G
Two 10GbE SFP+ ports network module with four physical ports with two SFP+ and two regular SFP ports
VS.Suresh.
*Plz rate the usefull posts *
Hi there,
C3KX-NM-10G
VS.Suresh.
metuckness
Perfect, thank you! I had been trying to figure out if there were specific ones that would have to be used but Wasn't seeing anything.
Now I just have to update the firmware for the switch stack because apparently there are issues with 10gig ports on the IOS version I have and I have to bump them up to at least 15.2 or there abouts.
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48       12.2(58)SE2           C3750E-UNIVERSALK9-M
     2 54    WS-C3750X-48       12.2(58)SE2           C3750E-UNIVERSALK9-M
     3 54    WS-C3750X-48       12.2(58)SE2           C3750E-UNIVERSALK9-M
     4 54    WS-C3750X-48       12.2(58)SE2           C3750E-UNIVERSALK9-M
Good luck running the stack on 15.X.
