Cisco 3835 Router Configuration problem
olakunle06
Hi there,
I have an issue with a Cisco 3825 router. When I try to save the running config it shows a paticular error. This same error is displayed when I run the SH START command.
Router#sh start
Using 1826 out of 491512 bytes
%Error opening nvram:/startup-config (Unknown error 0)
Router#
*Jun 27 10:51:36.087: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 10:51:36.311: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 10:51:36.311: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometr
y of nvram
Router#wr
startup-config file open failed (Unknown error 0)
Router#
*Jun 27 11:00:44.331: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 11:00:44.559: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 11:00:44.559: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometr
y of nvram
Router#
Pls can you help by telling me the source of the problem.
mheusing
Did you upgrade the IOS lately?
What you also can try:
Router#erase /all nvram:
Router#copy running-config startup-config
It might remove the error messages. Note: erase nvram is not sufficient.
Regards, Martin
7 Replies 7
royalblues
Level 10
Level 10
I think you are hitting the Bug CSCin98933.
Try upgrading the IOS to 12.4(07a), 12.4(7.20), 12.4(7.20)T
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCin98933
http://www.cisco.com/en/US/products/hw/cable/ps2209/products_field_notice09186a00807ee4b9.shtml
Narayan
olakunle06
The router I'm working on runs Cisco 12.4(11)T. This version is higher than those you mentioned. Could it be the same bug?
Could be...
If you can get a downtime, i would recommend upgrading it to the latest available train and check
Narayan
mheusing
Regards, Martin
It solved the issue. Apparently, it was an NVRAM problem. Erasing the nvram resolved the problem.
olakunle06
No I didn't upgrade the router. It's a brand new router.
robswanson
*Oct  8 17:13:04.835: NV: Invalid Pointer value(45E56768) in private configuration structure
*Oct  8 17:13:04.871: NV: Invalid Pointer value(45E56768) in private configuration structure
*Oct  8 17:13:04.871: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometry of nvram
Warning: Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]
router#erase startup-config
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
router#wr
Building configuration...
[OK]
