05-01-2019 01:17 PM
I'm running into an issue recently after we migrated all our switches from Brocade over to Cisco 3850's.
We have Cisco 3850-24XS with GLC-GE-100FX SFP's connected to a media converter then to a workstation and traffic is working fine.
At some point the interface will stop working and if I log into the switch and show the interface it says connected. I will unplug the fiber from the media converter and the switch interface still shows connected. I plug the fiber back in and I get fiber lights on my media converter but no traffic is being passed.
I can unplug the fiber from the switch and the interface still shows it's up/up even with no cables connected.
The only way to get the interface back up is to shu/no shu that interface.
Any idea why we are seeing this issue?
Eric
05-01-2019 03:24 PM
That is most likely a software bug. Try upgrading to a different version and test again.
05-01-2019 04:17 PM
05-01-2019 04:22 PM
We are currently running IOS XE 16.3.6
I'm going to work on upgrading to 16.9.1 but need to do some internal testing first.
