Cisco 3850 / 3750 switches performance and vlan configuration?
ashaktoms
I been asked to look into performance issues behind a number of Cisco 3850 /3850 switches and also figure out some clan configuration that is in place . Can you share some commends to get info on the Vlans and also see some performance markers ? I have some experience with Cisco Asa but not much with commend line . I assume you would use putty to ssh ? I was told 3 of them are part of a stack and the rest are in different buildings .
Jitendra Kumar
Yes, you can use putty for SSH for CLI access.
the best way you can check below troubleshooting guide.
https://www.cisco.com/c/en/us/support/switches/catalyst-3850-series-switches/products-tech-notes-list.html
Jitendra
