Cisco 3850 and HP DL360 10Gbe SFP+
campbellkay
Hi Guys,
Anyone have any experience connecting a Cisco 3850 with the 10GB module C3850-NM-2-10G to an
HP DL 360 Gen9
727060-B21 HPE FlexFabric 10Gb 2P 556FLR-SFP+ Adapter (FlexLOM)
i was looking at using the cisco DAC cables, instead of separate transceivers, does this work, if any have done it before?
Mark Malone
this is what 3850s support i would use something thats under supported range , if you use something unsupported Cisco will not assist if there is an issue
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/10GE_Tx_Matrix.html
Catalyst 3850 Series
Network Device
Transceiver Model
Minimum Software Release Required
DOM Support
Software Release
WS-C3850-24T
WS-C3850-24P
WS-C3850-48T
WS-C3850-48P
WS-C3850-48F
(With C3850-NM-2-10G or
C3850-NM-4-10G uplink modules)
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
XE 3.2.0SE
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
XE 3.2.0SE
XE 3.2.0SE
SFP-10G-ZR
SFP-10G-ZR-S
DWDM SFP+
XE 3.3.3SE
XE 3.3.3SE
CWDM SFP+
XE 3.7.0
XE 3.7.0
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
XE 3.6.0E
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.1E
XE 3.7.1E
WS-C3850-12XS
WS-C3850-16XS
WS-C3850-24XS
WS-C3850-32XS
(C3850-NM-8-10G uplink modules)
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-ZR
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
SFP-10G-ZR-S
DWDM SFP+
CWDM SFP+
SFP-H10GB-CU1M
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.1E
XE 3.7.1E
WS-C3850-48XS-S
WS-C3850-48XS-E
WS-C3850-48XS-F-S
WS-C3850-48XS-F-E
WS-C3850-48XS
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-ZR
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
SFP-10G-ZR-S
DWDM SFP+
CWDM SFP+
SFP-H10GB-CU1M
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.2
XE 3.7.2
WS-C3850-12S
WS-C3850-24S
C3850-NM-4-10G or
SFP-H10GB-CU1M
SFP-H10GB-CU3M
SFP-H10GB-CU5M
XE 3.3.3SE
SFP-10G-SR
SFP-10G-LRM
SFP-10G-LR
SFP-10G-ER
SFP-10G-ZR
SFP-10G-SR-S
SFP-10G-LR-S
SFP-10G-ER-S
SFP-10G-ZR-S
DWDM SFP+
XE 3.3.3SE
XE 3.3.3SE
CWDM SFP+
XE 3.7.0
XE 3.7.0
SFP-H10GB-CU1-5M
SFP-H10GB-CU2M
SFP-H10GB-CU2-5M
SFP-H10GB-ACU7M
SFP-H10GB-ACU10M
SFP-10G-AOC1M
SFP-10G-AOC2M
SFP-10G-AOC3M
SFP-10G-AOC5M
SFP-10G-AOC7M
SFP-10G-AOC10M
XE 3.6.0E
SFP-10G-BXD-I
SFP-10G-BXU-I
SFP-10G-BX40D-I
SFP-10G-BX40U-I
XE 3.7.1E
XE 3.7.1E
Yeah that plan was to use
SFP-H10GB-CU1M
just wasnt sure if it would work on the HP end.
