Cisco 3850 Crash on startup
Ross Phillips
Having problems with a brand new Cisco 3850. Crashes with a Kernel Panic error as listed below.
Im raising an RMA request and sending this switch back to Cisco so they can investigate but wanted to know if anyone else has seen this or had any luck fixing it.
ð
Booting...Initializing and Testing RAM +++@@@@####...++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@++@@done.
Memory Test Pass!
Base ethernet MAC Address: b4:e9:b0:40:94:00
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 74369252
Nova Bundle Image
Kernel Address    : 0x6042d350
Kernel Size       : 0x31794f/3242319
Initramfs Address : 0x60744ca0
Initramfs Size    : 0xdbe443/14410819
Compression Format: .mzip
Bootable image at @ ram:0x6042d350
Bootable image segment 0 address range [0x81100000, 0x81b80000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x811060f0 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
Data bus error, epc == ffffffff811a0a78, ra == ffffffff814e41c8
CRASHINFO_OOPS:
Oops[#1]:
Cpu 0
$ 0   : 0000000000000000 0000000000000010 8001190500000000 8001190400000000
$ 4   : 8001190000000000 0000010000000000 8001190500200000 8001190500200000
$ 8   : 8001190500200000 0000180000000000 0000000000000001 ffffffff81a433e0
$12   : 0000000000000020 ffffffff81105f8c ffffffff81a1c000 0000000000000000
$16   : 8001190500000000 8001190500200000 0000000000000000 a80000010803fc80
$20   : ffffffff81ae0000 0000000000000002 0000000000000000 0000000000000000
$24   : a800000108561030 ffffffff81429d58
$28   : a80000010803c000 a80000010803fbf0 0000000000000000 ffffffff814e41c8
Hi    : 0000000000000001
Lo    : 1111111111111112
epc   : ffffffff811a0a78 cvmx_pcie_config_read32+0xb8/0x110
    Not tainted
ra    : ffffffff814e41c8 octeon_pcie1_read_config+0x1f8/0x2a0
Status: 10008ce2    KX SX UX KERNEL EXL
Cause : 4080801c
PrId  : 000d900a (Cavium Octeon II)
Modules linked in:
Process swapper (pid: 1, threadinfo=a80000010803c000, task=a800000108038b38, tls=0000000000000000)
Stack : 0000000000000000 0000000000000000 0000000000000000 0000000000000000
        a8000001082dde80 a80000010855a400 0000000000000000 ffffffff814e41c8
        0000000000000004 a800000108559000 ffffffff81b53e28 a80000010803fcd0
        ffffffff81b50000 0000000000000001 a80000010855a400 ffffffff81ae0000
        0000000000000000 ffffffff813f560c 0000000081a763f0 ffffffff81a763f0
        0000000000000000 0000000000000000 0000000000000000 a80000010855a400
        0000000000000000 0000000000000000 0000000000000008 ffffffff81106f44
        0000000000000000 a80000010855a400 ffffffff813f6b7c a80000010855a400
        a80000010855a400 0000000000000000 0000000000000008 ffffffff81ae0000
        0000000000000000 ffffffff813f79e4 0000000000000000 a80000010855a400
Call Trace:
[<ffffffff811a0a78>] cvmx_pcie_config_read32+0xb8/0x110
[<ffffffff814e41c8>] octeon_pcie1_read_config+0x1f8/0x2a0
[<ffffffff813f560c>] pci_bus_read_config_dword+0x84/0xc0
[<ffffffff81106f44>] pci_scan_single_device+0x7c/0x188
[<ffffffff813f79e4>] pci_scan_slot+0x2c/0xe0
[<ffffffff81108454>] pci_scan_child_bus+0x40/0x100
[<ffffffff81108538>] pci_scan_bus_parented+0x24/0x3c
[<ffffffff8110daa8>] pcibios_scanbus+0x74/0x138
[<ffffffff81abbae0>] pcibios_init+0x20/0x5c
[<ffffffff81115ad0>] do_one_initcall+0x38/0x180
[<ffffffff81a9c32c>] kernel_init+0x1c8/0x270
[<ffffffff811ac660>] kernel_thread_helper+0x10/0x18
Code: 00e84025  11000011  dfbf0038 <8d030000> dfbf0038  dfb10030  00032e02  00031600  3064ff00
Disabling lock debugging due to kernel taint
KOOPS: Failed to create koops file /crashinfo/koops.dat
Fatal exception: panic in 5 seconds
BUG: scheduling while atomic: swapper/0x00000001/1, CPU#0
Modules linked in:
Call Trace:
[<ffffffff8110e100>] dump_stack+0x8/0x34
[<ffffffff8110efe0>] __schedule+0x770/0x990
[<ffffffff8110f350>] schedule+0x10/0x28
[<ffffffff8110f758>] schedule_timeout+0x190/0x350
[<ffffffff811f5ab8>] msleep+0x28/0x38
[<ffffffff811b06b4>] die+0x134/0x150
[<ffffffff811b1634>] do_be+0x19c/0x1a0
[<ffffffff81100984>] ret_from_exception+0x0/0x10
Kernel panic - not syncing: Fatal exception
ð
InayathUlla Sharieff
Ross,
Has the device came back online after the crash?
If no then there is a hardware issue and you have done the right job of creating the RMA for the same.
Inayath
Ross,
Inayath
No I went through the recovery procedure and tried to perform the emergency-install from rommon but as soon as it boots the recovery image it crashes again.
Got it. I would suggest no more troubleshooting go ahead with RMA and get a new box.
Inayath
**** Please mark this thread as answered if this has answered your query***
