Cisco 3850 High Output Errors and drops after upgrade to 3.0.7.0.3E
bern.rain
Hello Guys
Customer contacted me that after the upgrade of his 3850-24T to version 3.0.7.0.3E he received high output errors on the interface. (only the interfaces which are conneted to his ESX Servers). He also tried Version 03.06.04 and here is same.
Only with Version 03.03.05 all is fine
Does anyone have an idea why? i also did not fined something in the Bug Search
Bernhard
interface GigabitEthernet1/0/1
description TRUNK-TO-ESX-01
switchport trunk allowed vlan 60
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 2c3e.cf67.7581 (bia 2c3e.cf67.7581)
Description: TRUNK-TO-ESX-01
MTU 9000 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:43, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 1104550142
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1755000 bits/sec, 51 packets/sec
5 minute output rate 633000 bits/sec, 37 packets/sec
819961929 packets input, 1485512498911 bytes, 0 no buffer
Received 139980 broadcasts (116669 multicasts)
0 watchdog, 116669 multicast, 0 pause input
948814884 packets output, 6262723491506 bytes, 0 underruns
1104550142 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Carlos Villagran
Hi!
Can you please use clear counters interface giga 1/0/1?
We should monitor if these counters are incrementing.
Best regards!
JC
Hello Carlos
Customer did the Rollback to 03.03.05 but i did the clear counters at first but the counters are incrementing.
Bernhard
Hi!
Are they still incrementing after the rollback?
Regards!
JC
Hello Carlos
After the rollback all is fine and no error or drops anymore
Bernhard
