Cisco 3850 Inline Power Operation Status Off
fdharmawan
Level 4
Level 4
Hi Guys,
One of my switch unit suddenly lose the PoE capability. Switch type is WS-C3850-24XU. Below is the output when I do some checking.
FaultySwitch#show platform software ilpower system 2
ILP System Configuration
Slot: 2
ILP Supported: Yes
Total Power: 0
Used Power: 0
Initialization Done: Yes
Post Done: Yes
Post Result Logged: No
Post Result: Success
Power Summary:
Module: 0
Power Total: 0
Power Used: 0
Power Threshold: 0
Operation Status: Off
Pool: 2
Pool Valid: Yes
Total Power: 0
Power Usage: 0
Here is the comparison on the normal switch.
NormalSwitch#show platform software ilpower system 1
Slot: 1
ILP Supported: Yes
Total Power: 1440000
Used Power: 187440
Post Done: Yes
Power Summary:
Module: 0
Power Total: 1440000
Power Used: 187440
Power Threshold: 0
Operation Status: On
Pool: 1
Pool Valid: Yes
Power Usage: 187440
Is it possible the PoE feature just turned off for some reason? Thanks.
6 Replies 6
Mark Elsen
   - Is there anything in the logs (when that happened)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi Marce,
Yes, here is the log I found on the switch.
%PLATFORM_STACKPOWER-4-BISP_PORT_A_SC: Switch 2 experienced a short-circuit BISP event on port 1
                             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtj52215
     Whether the bug report matches or not , consider using the latest advisory software release for the 3850 and check if that can help
 M.
       Beauty and terror
      Just keep going
       No feeling is final
 are both the working and the non-working unit running the same IOS-XE version ?
Release Gibraltar-16.12.5b MD is the recommended release...
Hi Georg,
Yes, both switch are the same type and running the same OS, 16.3.7. Even they are on the same stack.
Leo Laohoo
  1. What is the exact IOS-XE version is the switch/stack running on?
  2. What is the uptime of each switch member?
  3. Are there any SFP/SFP+ optics installed?
