Showing results forĀ
Search instead forĀ
Did you mean:Ā
cisco 3850 ip base private vlan issue
n.bokhar1
hi
i have a few 3850-24t-s s and i want to configure private vlan on them and one of the reasons i bought the model was because of private vlan capabilities but now i dont now how to enable it
i put vtp on transparent and off mode
but i don't have private vlan command on vlan config how can i use private vlan on this device ?
please help me
Jon Marshall
It may be the version of software you are running.
Looking at the release notes for the 3850s support for private vlans was added in IOS XE 3.7 and you need IP Base at a minimum.
Jon
thanks but that is under AP features and is there any way i can achieve that without upgrading to a ED os because my devices are production devices i can't risk reliability
What do you mean by AP features ?
What version of IOS XE as you running ?
Jon
