Cisco 3850 LACP to a HP 5920
Timothy.Sutton
I cannot seem to get this working correctly. I am trying to get a Cisco 3850 to talking to a HP 5920 over LACP. When I go to ping between the two devices I get nothing.
Cisco Configuration
interface Port-channel4
switchport trunk allowed vlan 2,51,400
switchport mode trunk
switchport nonegotiate
no port-channel standalone-disable
spanning-tree bpdufilter enable
interface TenGigabitEthernet1/0/46
no cdp enable
channel-protocol lacp
channel-group 4 mode active
lacp rate fast
interface TenGigabitEthernet1/0/48
no cdp enable
lacp rate fast
HP Configuration
interface Bridge-Aggregation2
port link-type trunk
undo port trunk permit vlan 1
port trunk permit vlan 2 51 400
link-aggregation mode dynamic
interface Ten-GigabitEthernet1/0/23
port link-mode bridge
lacp period short
port link-aggregation group 2
interface Ten-GigabitEthernet1/0/24
lacp period short
Any help would be great.
11 Replies 11
Timothy.Sutton
Status for Port Channel from Cisco
show interfaces Port-channel 4
Port-channel4 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 50f7.2210.87b0 (bia 50f7.2210.87b0)
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is
input flow-control is off, output flow-control is unsupported
Members in this channel: Te1/0/46 Te1/0/48
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
5 minute output rate 4000 bits/sec, 5 packets/sec
8606 packets input, 1162852 bytes, 0 no buffer
Received 8606 broadcasts (8605 multicasts)
0 watchdog, 8605 multicast, 0 pause input
29649 packets output, 2552866 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
Port Status: S -- Selected, U -- Unselected, I -- Individual
Flags: A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
D -- Synchronization, E -- Collecting, F -- Distributing,
G -- Defaulted, H -- Expired
Status from Bridge Aggregation on the HP device.
Aggregate Interface: Bridge-Aggregation2
Aggregation Mode: Dynamic
System ID: 0x8000, d894-037b-e3ad
Local:
Port Status Priority Oper-Key Flag
XGE1/0/23 S 32768 2 {ABCDEF}
XGE1/0/24 S 32768 2 {ABCDEF}
Remote:
Actor Partner Priority Oper-Key SystemID Flag
XGE1/0/23 303 32768 4 0x8000, 50f7-2210-8780 {ABCDEF}
XGE1/0/24 305 32768 4 0x8000, 50f7-2210-8780 {ABCDEF}
I am not sure if the Cisco side needs 'switchport trunk encapsulation dot1q', can you give that a try ? Also, which VLAN do you have marked as tagged on the HP side ?
I was trying to keep the Cisco unchanged, but I can attempt to make that change.
As far as tagging on the HP device I think you are thinking of their other version of the OS, this one works closer to Cisco trunk method from what I have read.If I go to the vlan there is no tag command.
Also believe the switchport trunk encapsulation dot1q command has been deprecated out of the version of the Cisco software I am running. So that is not going to provide any change.
Not familiar with HP but can you provide the info for what IP and in what vlan you are trying to ping?
Is HP layer-2 only and the gateway for all vlans on the 3850?
I am trying to just ping IP address on the same vlan right now.
So if I look at vlan 400 on both devices they look like this.
HP
interface Vlan-interface400
ip address XX.XX.XX.1 255.255.255.0ping
Cisco
interface Vlan400
ip address XX.XX.XX.10 255.255.255.0
ip directed-broadcast
end
Basically try pinging either device from the same vlan and it doesn't work.
Timothy,
Can you please share the release you are runnign in the 3850 'show version', the command ' show etherchannel summ' and 'show lacp count'?
Thanks!
show release
Cisco IOS XE Software, Version 16.06.01
Cisco IOS Software [Everest], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.6.1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 22-Jul-17 03:00 by mcpre
show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
3 Po3(SU) PAgP Te1/0/1(P) Te2/0/1(P)
4 Po4(SU) LACP Te1/0/46(P) Te1/0/48(P) Te2/0/46(D)
Te2/0/48(D)
 show lacp counters
LACPDUs Marker Marker Response LACPDUs
Port Sent Recv Sent Recv Sent Recv Pkts Err
Channel group: 4
Te1/0/46 90277 86306 0 0 0 0 0
Te1/0/48 90233 86297 0 0 0 0 0
Te2/0/46 0 0 0 0 0 0 0
Te2/0/48 0 0 0 0 0 0 0
I am not sure how the HP 5920 handles the native VLAN, but try and remove all 'allowed vlan' commands from both the Cisco and the HP side.
Also, on a port channel between Cisco switches, it is recommended to have matching channel numbers. So try and change your interface Bridge-Aggregation2 to interface Bridge-Aggregation4...
Thanks Buddy
its Really Helpful to understand what to do with hp
Hello
Try changing the following
Cisco
conf t
no int port 4
default interface TenGigabitEthernet1/0/46
default interface TenGigabitEthernet1/0/48
shut
shut
int port 4
description HP Fibre switch
switchport trunk allowed vlan vlan 2,51,400
no shut
HP
vlan 2
vlan 51
vlan 400
lldp compliance cdp
lldp global enable
no lacp period short
Kind Regards
Paul
