CISCO 3850 PoE+ SWITCH
ameyjoshi81
I have a device which is a PoE device (IEEE802.3af). Can Cisco 3850 PoE+ (IEEE802.3at) support both data and power to Normal PoE (IEEE802.3af) devices.
Please confirm.
Amey
Jose Solano
Level 4
Level 4
See this:
3850 PoE, PoE+, and Cisco UPOE Ports
The PoE+ and Cisco Universal Power Over Ethernet (Cisco UPOE) ports use the same connectors as described in the "10/100/1000 Ethernet Ports" section.
They provide:
•PoE+ ports: Support for IEEE 802.3af-compliant powered devices (up to 15.4 W PoE per port) and support for IEEE 802.3at-compliant powered devices (up to 30 W PoE+ per port). The maximum total PoE power in a 1RU switch is 1800 W.
•Cisco UPOE ports: Support for powered devices on all four Ethernet signal pairs (up to 60 W Cisco UPOE per port).
•Support for Cisco-enhanced PoE.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3850/hardware/installation/guide/HIGOVERV.html#wp1351798
