Cisco 3850 - stop rollback after reboot
mikiNet
Hi all!
It is possible to stop software rollback after a reboot switches (I have 4 stack switches)
I accidentally hit "enter" key when I write software rollback, but I don't want it.
When switch finish this command, ask me if I want to reload but I hit "n"
But on the output I saw information that previous IOS XE will install after reboot.
How can I stop this proces ?
No software rollback doesn't work, software no rollback also doesn't work
6 Replies 6
Mark Malone
haven't tested this but check your show boot system see if its showing that new image then change the boot parameter with boot system flash: see if that changes it back to what you want
show boot
Switch 1
Current Boot Variables:
BOOT variable = flash:cat3k_caa-universalk9.SPA.03.06.02a.E.152-2a.E2.bin;
Boot Variables on next reload:
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
....................#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
.....................(config)#boot system ?
  flash:      System image file
  switch      Set system image for switches in the stack
  tftp:       System image file
  usbflash0:  System image file
(config)#boot system flash:
Switch 1
BOOT variable does not exist
BOOT variable = flash:packages.conf
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
Switch 2
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
Switch 3
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
Switch 4
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
Switch 5
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
Switch 6
Allow Dev Key = yes
Manual Boot = no
Enable Break = no
IOS XE is on INSTALL mode..
It is possible that the file packages.conf was changed after software rollback ?
It depends if there is multiple packages.conf files in flash check-- dir-- for flash see whats in it , if theres only 1 it cant roll back to anything else but what it was already on if it was to reboots , there needs to be multiple packages for it to do a rollback
you could also force the flash into bundle mode then load a .bin that its currently using so if was to reboot you would be sure your definitely on the current correct image
In flash I have got:
 7750  -rwx     2097152  Jul 28 2016 13:20:37 +02:00  nvram_config
 7748  drwx        4096  Mar 27 2015 19:03:40 +01:00  onep
 7747  -rw-   257651868  Aug 21 2015 18:50:40 +02:00  cat3k_caa-universalk9.SPA.03.03.05.SE.150-1.EZ5.bin
 7754  -rw-    79122052  Aug 21 2015 19:07:04 +02:00  cat3k_caa-base.SPA.03.03.05SE.pkg
 7756  -rw-     6521532  Aug 21 2015 19:07:04 +02:00  cat3k_caa-drivers.SPA.03.03.05SE.pkg
 7757  -rw-    34530288  Aug 21 2015 19:07:04 +02:00  cat3k_caa-infra.SPA.03.03.05SE.pkg
 7751  -rw-        1234  Mar 27 2015 17:35:17 +01:00  packages.conf
 7746  -rw-        1396   Jul 5 2016 12:54:56 +02:00  vlan.dat
 7755  -rw-       16913  Jul 28 2016 14:01:44 +02:00  wnweb.tgz
 7758  -rw-    34846028  Aug 21 2015 19:07:04 +02:00  cat3k_caa-iosd-universalk9.SPA.150-1.EZ5.pkg
 7760  -rw-    25170832  Aug 21 2015 19:07:04 +02:00  cat3k_caa-platform.SPA.03.03.05SE.pkg
 7761  -rw-    77456192  Aug 21 2015 19:07:05 +02:00  cat3k_caa-wcm.SPA.10.1.150.0.pkg
69697  drwx        4096  Mar 27 2015 18:27:57 +01:00  vman_fdb
61955  -rw-    82245716  Mar 27 2015 17:35:11 +01:00  cat3k_caa-base.SPA.03.07.00E.pkg
61956  -rw-     7019196  Mar 27 2015 17:35:11 +01:00  cat3k_caa-drivers.SPA.03.07.00E.pkg
61957  -rw-    36901896  Mar 27 2015 17:35:11 +01:00  cat3k_caa-infra.SPA.03.07.00E.pkg
61958  -rw-    45841724  Mar 27 2015 17:35:11 +01:00  cat3k_caa-iosd-universalk9.SPA.152-3.E.pkg
61959  -rw-    26858380  Mar 27 2015 17:35:12 +01:00  cat3k_caa-platform.SPA.03.07.00E.pkg
30978  -rw-   111475520  Mar 27 2015 17:35:12 +01:00  cat3k_caa-wcm.SPA.10.3.100.0.pkg
 7753  drwx        4096  Mar 27 2015 18:27:57 +01:00  virtual-instance
77441  drwx        4096  Mar 27 2015 18:30:37 +01:00  dc_profile_dir
77443  drwx        4096  Mar 27 2015 18:32:11 +01:00  wnweb_store
Now switch using 03.03.05 IOS XE, when I make a mistake that I hit enter after write software rollback command, switch give information that after reboot it restore 03.07.00
On next week I will process upgrade switch from 03.03.05 to suggested (3.6.5) so maybe when I write software install NEWIOSXE then switch overwrite earlier command (software rollback)
jdesanti
Software rollback is functional only when at least one rollback package with the file name packages.conf.00- is present.
I don't see any .conf.00 file on your flash, however to make sure, you can do "more flash:packages.conf" and verify which version is pointing your packages.conf file, that is the version your switch is going to run on the next reboot.
more flash-1:packages.conf
#! /usr/binos/bin/packages_conf.sh
iso   rp 0 0   rp_base       cat3k_caa-base.SPA.03.07.00E.pkg
iso   rp 0 0   rp_infra       cat3k_caa-infra.SPA.03.07.00E.pkg
iso   rp 0 0   rp_platform       cat3k_caa-platform.SPA.03.07.00E.pkg
iso   rp 0 0   rp_iosd       cat3k_caa-iosd-universalk9.SPA.152-3.E.pkg
iso   rp 0 0   rp_wcm       cat3k_caa-wcm.SPA.10.3.100.0.pkg
iso   rp 0 0   drivers       cat3k_caa-drivers.SPA.03.07.00E.pkg
# -start- superpackage .pkginfo
# pkginfo: Name: rp_super
# pkginfo: PackageFileType: iso
# pkginfo: BuildTime: Mon Dec 08 00:35:25 PST 2014
# pkginfo: ReleaseDate: Mon Dec 08 00:35:25 PST 2014
# pkginfo: .BuildArch: mips
# pkginfo: RouteProcessor: mips
# pkginfo: Platform: ng3k
# pkginfo: User: XXX
# pkginfo: PackageName: cat3k_caa-universalk9
# pkginfo: Build: 03.07.00.E
# pkginfo: Dependencies: PROVIDES:cat3k_caa-base,03.07.00E,mips;cat3k_caa-infra,03.07.00E,mips;cat3k_caa-platform,03.07.00E,mips;cat3k_caa-iosd-universalk9,152-3.E,mips;cat3k_caa-wcm,10.3.100.0,mips;cat3k_caa-drivers,03.07.00E,mips;
# pkginfo: .SupportedBoards: unknown
# pkginfo: .BuildPath: unknown
# pkginfo: BuildType: Production
# -end- superpackage .pkginfo
