Cisco 3850 swich
ddesai
When I have configured this command crypto key generate RSA key was generated for 2048 but when I login to switch I could not see crypto key I could not find anything while my other switch already there.
5 Replies 5
Mark Elsen
              - Try this command : show crypto key mypubkey rsa
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Key generated but not showing on switch while have verify show run command while other switch showing,
Is the other switch exactly the same model of switch and running the exact same software?
Please post the output of the command requested by @Mark Elsen
Rick
Cisco Catalyst 3850-48P-E Switch  switch model I am facing issue
M02@rt37
Hello @ddesai,
@Mark Elsen give you the answer !
Best regards
