Cisco 3850 Switch won’t boot
nojima
I have a Cisco 3850 switch that goes straight into recovery mode when I power on. I loaded the newest update but it won’t boot when powered on. It will however boot when I use “switch: boot flash:file name” Any ideas on how to get it to boot properly ?
Seb Rupik
Hi there,
If you are happy to run the switch in BUNDLE mode then set the boot var in config:
no boot system
boot system switch flash:<file_name>
Or you could attempt the installation again:
request platform software package install switch flash:<file_name>
...this will recreate the required files and packages.conf which is used for booting.
cheers,
Seb.
Leo Laohoo
If the switch is still in ROMMON, post the complete output to the following commands:
  • set
  • dir flash:
