Cisco 3850 Switch
nabeelcse07
I am using cisco 3850 switch with 350W power supply. I want to know about the current requirement at the time switch powers on. Anyone can help Please..
NA
pwwiddicombe
Level 4
Level 4
At the time the switch powers on, there will typically be a surge up to the 350W limit; afterwards it will drop off considerably (i.e. within a second or so).  Depending on PoE devices and SFP's, you might find it runs 100-150W.
PoE will subsequently be enabled, and will then start activating any PoE devices attached, up to the switch PoE limitation.
