Cisco 3925 and SFP modules
I'm trying to install a MGBSX1 into the Cisco 3925 but it's doesn't seem it's detecting it for some reason.
I've changed media type and I've tested with another SFP module (GLC-SX-MM) which works fine.
Am I missing a command to enable this type of module on the Cisco 3925?
acampbell
Looking at the SFP compatability table for 39XX series routers.
http://www.cisco.com/c/en/us/products/routers/3900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html#formfactor
The MGBSX1 is NOT mentioned
Looks like the MGBSX1 is only compatable with the Small Business switch family.
http://www.cisco.com/c/dam/en/us/td/docs/interfaces_modules/csbna/mgb/quick_start/guide/Optical_Module_QSG_en-US.pdf
Alex
Regards, Alex. Please rate useful posts.
Crud. I checked compatibility before ordering as well but obviously didn't pay close enough attention.
