Cisco 3945 with Layer2/3 Switch Module
dastrix80
Hi Guys
Ive got a 24 port GIG module in this 3945 ISR.
Im using BVI to place an IP address on the VLAN1 of the router, which is my LAN default gateway. Rather than having to initiate connections to the Switch Module for configuration using 'service module GigabitEthernet 1/0 session" id like to put an IP on VLAN1 of the Switch module. I've done this however its not pingable from the LAN
Any thoughts as to why? Id like to enable SSH to this switch module so I can manage it like any other device, rather than via the Router.
Kris
dastrix80
Solved, just took a while for a ping to reply :D
