cisco 4006 Switch problem
muraripadhan
I plug out directly to Cisco 4006 Switch after some time i plug in the power cable.
Supervisor Engine is showing flashing Amber.
Other Modules 10/100/1000BaseTX are shown RED.
I tried to access console but i can not.
What may be the problem and what are solution please suggest me.
5 Replies 5
Leo Laohoo
Supervisor may have booted in ROMmon or is dead.
Respected Sir,
Please suggest me what i will do.
It will work or not
My regular response would be "contact Cisco TAC and arrange for an RMA".  But seeing that it's a legacy Catalyst 4006, I really doubt if the supervisor card is still under maintenance.
My recommendation is to contact a reputable system integrator and think about getting the chassis upgraded to something more recent like the 9300 or the 9400.
Thank you sir...
It running since 15 years sir so i think this device need rest.........
The first Cisco core switch I supported was a 4006 with Sup2 (CatOS) and that was way back 2005.
