Cisco 4221 - Unable to connect to console
I'm trying to install a Cisco 4221 router and I'm struggling to connect to the console to do the initial setup.  I'm following this guide
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/hardware/installation/guide4400-4300/C4400_isr/Install_Connect.html#97374
and using a Mac (OS v10.12).  Here's how I'm trying to connect:
Mac (USB port) -> USB to Ethernet adaptor -> Crossover cable -> Blue console RJ45 port on 4221
When I do ls -ltr /dev/*usb* the mac shows no results.
Any ideas what I'm doing wrong?
Thanks!
HI !
Can you please remove everything then connect step by step.
Just open putty or hyperterminal ,, then start the router . i hope it will work .
CRaju
Many thanks for the diagram!  I will order those cables now and try it out.
