Cisco 4331 throughput
suryakumar90
Hello All,
Can somebody let me know how to calculate througput on cisco 4331 ISR,
We are having currently running with 100 Mbps throughput and link speed is 70 Mbps.
Please let me know it enough for 100 Mbps or i need to upgrade to 300 Mbps
Joseph W. Doherty
70 Mbps duplex? If so, the 100 Mbps throughput is total aggregate capacity of the router. So, for example, to support 70 Mbps duplex, you would need the 300 Mbps license.
However, if your 70 is asymmetric bandwidth, where the sum of up/down is 100 or less, you should be okay with your 100 Mbps license.
