09-29-2016 06:19 AM - edited 03-08-2019 07:37 AM
Hi everyone,
I'm learning about SFP stuff at the moment.
I understood almost everything I had to know except for one thing I can't find on the internet.
Can I use different a SFP from one side, say a Fabric Interconnect that supports SFP GE T (copper not fiber) and a GLC-T the other side, say a Catalyst TOR (copper between the SFPs)
Thanks !
Solved! Go to Solution.
09-29-2016 07:22 AM
No, it will not work. Both sides of the cable need to have the same type of transceiver.
HTH.
09-29-2016 07:22 AM
HTH.
10-13-2017 01:39 AM
10-13-2017 06:05 AM
