Cisco 4500 and redundant supervisors possible problem
IgorHamzic
Hi. I have a Cisco 4500 switch with two supervisor modules. The modules are supposed to be in failover state but I get the following results when entering sh module and sh redundancy states:
sh module
Mod Ports Card Type Model Serial No.
1 2 Supervisor II+ 1000BaseX (GBIC) WS-X4013+ xxxxx
2 Supervisor
my state = 13 -ACTIVE
peer state = 1 -DISABLED
Mode = Simplex
Unit = Primary
Unit ID = 1
Redundancy Mode (Operational) = Non Redundant
Redundancy Mode (Configured) = RPR
Split Mode = Disabled
Manual Swact = Disabled Reason: Simplex mode
Communications = Down Reason: Simplex mode
client count = 22
client_notification_TMR = 240000 milliseconds
keep_alive TMR = 9000 milliseconds
keep_alive count = 0
keep_alive threshold = 18
RF debug mask = 0x0
It was my belief that the second supervisor should be recognized right away. Could this indicate that the second supervisor module isn't working correctly?
wdrootz
Level 4
Level 4
This indicates that second supervisor is either not present or hadn't booted up.
Mode = Simplex
This specifies that chassis is not in redundancy.
Check if the second sup is in ROMMon and bring it up.
