cheat sheets???
luke_tech
Community Member
i'm am currently doing my ccna & ccnp classes for my certification's, but i'm having problems remembering all the switch/router commands for programming them. I didn't know if there where cheat sheets for these commands that way i could use for studying and have for my notes. Any help would be greatly appreciated!!
keeleym
Level 9
Level 9
Hi There
Not really cheat sheets, but Cisco Press print command references for the CCNA (though I am not sure the one for the new CCNA is out yet) and also each of the four tracks of the CCNP which are really useful to have to hand.
See here http://www.amazon.co.uk/s/ref=nb_ss_w_h_?url=search-alias%3Daps&field-keywords=CCNA+Command+reference&Go.x=0&Go.y=0&Go=Go
and here http://www.amazon.co.uk/CCNP-BSCI-Portable-Command-Guide/dp/1587201895/ref=pd_bbs_sr_11?ie=UTF8&s=books&qid=1195246660&sr=8-11
Also don't underestimate the usefulness of Cisco IOS help 😉
Best Regards,
Michael
guruprasadr
Level 11
Level 11
HI, [Pls Rate if HELPS]
Refer the Attachment (.zip) for CCNA and CCNP CISCO Press Command Reference Manual.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Danilo Dy
If you have access to a switch or a router. Practicing the commands is better than memorizing them. It's like writing them at the back of your hand
Else, you can use Dynagen http://www.dynagen.org/
Dandy
