Cisco 4500 Switch - SNMPV3
MoSalah
   I have recently configured SNMPV3 with Cisco 4500
# snmp-server view myview iso included
# snmp-server group ciscogroup v3 auth read myview write myview
# snmp-server user cisco ciscogroup v3 auth sha usercsico
# snmp-server host 10.x.x.x traps version 3 auth cisco
-SNMP Manager can not see any packets from my node even snmpwalk authentication is succeeded , when show snmp logging , there is packets out of the switch but with wrong time ! , NTP Server is configured and show clock indicated the correct time .
- is there any modification should I do to the configuration ? or the time of the logging is not related  ?
7 Replies 7
marce1000
 - Have a fallback to snmp v2c for testing the snmp manager software in combination with your device. If that works have a look into the current software version running on the 4500. Snmp v3 is sometimes buggy on cisco switches. Depending on urgency and feasibility and compare the problem with more recent release(s) , if available.
 M.
Thanks marce for your concern
  I have a fallback already to v2c and it worked !
is there any chance or additional configuration to perform SNMPV3 as it is mandatory ?
 (also pay attention to the software versioning matter as I explained earlier).
 M.
Version :   IOS XE 3.10.3
Do you have comments on it ?
 - Advise is to check Release Notes of subsequent versions , check for instance Resolved Caveats and look for improvements or corrections concerning snmp (you can use for instance use Find in Browser).
 M.
Reza Sharifi
Not sure what management application you use, but here is the config needed for SW application.
https://thwack.solarwinds.com/t5/Engineer-s-Toolset-Documents/How-to-properly-configure-SNMPv3-in-CISCO/ta-p/516733
Hello
@MoSalah wrote:
Try to specify athe nms host in a ACL for the user and group to use authentication, Also s that auth password correct and not a typo?
ip access-list standard snmp_acl
remark NMS server
permit ip 1.1.1.1
snmp-server group ciscogroup v3 auth read myview write myview access snmp_acl
snmp-server user cisco ciscogroup v3 auth sha usercsico usercsio
Makes me think ,Does the nms host support SHA authentication?
Kind Regards
Paul
