Cisco 4500x peer reload
DarylBrooks
This should be a really simple question but I can't find a definite answer elsewhere.
When running the command 'Redundancy reload peer' in order to reload the peer supervisor in a live firmware upgrade scenario, will the ports on the peer switch go down, or does the active supervisor have complete control over these ports whilst the peer supervisor is reloading?
I hope this makes sense.
Thanks in advance.
Daryl
Rolf Fischer
Level 9
Level 9
when you reload the VSS peer switch, you'll also loose all the peer switch ports.
When you follow the "dual attach" design rule, all of the (multi-chassis) etherchannels will just loose one ore more port-channel member ports; so your network should stay operational but with half of its capacity.
Rolf
Rolf Fischer
Level 9
Level 9
Rolf
Thanks for your quick response Rolf,
That was exactly what I thought but it wasn't clear in documentation.
