Cisco 4500X port/module naming convention
darren-carr
Level 2
Level 2
Hi all,
Just a quick question as I can't seem to find this information and don't have access to a 4500X.
When you have two 4500X and you connect them using VSS how are the ports referenced for a 16/32 port switch?
Is it
switch/module/port
i.e. 1/0/1 (for switch 1, port 1) and 2/0/1 (for switch 2, port 1)?
Also, if I add the 8 port uplink module would port 33 or 17 be addressed as
i.e 1/1/1 or 1/0/33 (on the 24 port switch) i.e. is the uplink module seen as module 1 (0 is used for the fixed switch port module in the chassis).
Darren
InayathUlla Sharieff
