Additional GigEthernet Rj45(TX) Option for 7200VxR ?
Haris P
Level 4
Level 4
Dear All ,
Is there is any additional RJ45 Gigethernet Option for 7200VxR routers . I search on cisco and Unfortunately i didn't find any Gig ethernet PA for 7200VxR other than PA-GE . PA-GE only supports fiber but I need ethernet
Haris P
paolo bevilacqua
You would use a copper GBIC for that.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Considering the performance limitations of a 7200, you might also consider trunking an existing interface to a switch.
Vignesh Rajendran Praveen
Hi Haris,
Your requirement is not possible. It is possible with a FastEthernet requirement by using PA-2FE.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
