Cisco 4500X VSS port-channel issue after upgrading
PECET
Hello Everyone,
I am currently encountering an issue after upgrading 2 4500X in VSS. One of the switches has boot in Rommon. After a lot of reloading, booting in Rommon, and unable to establish VSS again, I've decided to convert them back to standalone mode using the switch convert mode stand-alone command.
Now that they have been both upgraded to 3.11.3aE, I've followed the steps here - https://community.cisco.com/t5/networking-documents/virtual-switching-system-vss-configuration-for-cisco-4500-series/ta-p/3147865#toc-hId--764944615 for the VSS configuration. After issuing the switch convert mode virtual​ command, they have reloaded but were unable to establish VSS. I've also noticed that the port-channels' status are DOWN but the port interfaces are UP. I've converted them back again to standalone mode for now in order to troubleshoot the DOWN status of the port-channels. Nothing was touched or changed. Also checked the SFPs and fiber cable so I don't know why the port-channels are DOWN.
Am I missing anything or encountering a bug? I am hoping for any suggestions at this point. Thank you in advance everyone.
Here are snippets of configuration from the standalone mode switches:
Switch 1:
switch virtual domain 100
                                         <-- I don't know why switch 1 command is not appearing here
mac-address use-virtual
interface Port-channel10
switchport
switchport mode trunk
switchport nonegotiate
switch virtual link 1
interface TenGigabitEthernet1/1
no cdp enable
no lldp transmit
no lldp receive
channel-group 10 mode on
service-policy output VSL-Queuing-Policy
Switch 2:
switch 2 priority 110
interface Port-channel20
switchport
switch virtual link 2
no cdp enable
no lldp transmit
no lldp receive
channel-group 20 mode on
Hi, I've found the cause of the port-channel not forming. I've encountered this bug here - https://community.cisco.com/t5/cisco-bug-discussions/cscsq36972-portchannel-does-not-form-log-messages-indicate/td-p/2585565
Followed the workaround and it worked. Hope this will be useful for those who would encounter this issue.
5 Replies 5
Leo Laohoo
Did you upgrade the ROMMON?
In the Release Notes, it is stated:
If you are upgrading to Cisco IOS XE Release 3.9.xE and plan to use VSS, you must upgrade your ROMMON to IOS Version 15.0(1r)SG11.
Hi, our ROMMON version is 15.0(1r)SG12. Since it is higher than 15.0(1r)SG11, I assume there is no need to upgrade?
Ok, so that eliminates the cause why the secondary boot into ROMMON.
How about the config-registry?  It is set to 0x2101 or 0x2102?
Can you console into the secondary and reboot?  We want to see what it is doing wrong.
Both switches are in 0x2102. I can't console the secondary right now. I'll let you know if someone from the office can. The issue I am encountering right now is I can't get their port-channel status to go UP (both in standalone mode). That is why every time I convert them to mode virtual, they can't see each other and can't establish VSS.
