Terminal is slow to react in configuration mode Cisco catalyst 9200
NicP
I have some weird behavior.
My Cisco Catalyst 9200 switch reacts slowly on whichever command i type in configuration mode, while in exec and enabled mode it reacts at normal speed.
It is the same behavior in on SSH as on Serial.
2 days ago I did configure it without any problem, and after a reboot still worked normal. I'm the only one who have managed the config of the switch.
The only thing that changed is that the switch has been moved to the rack in another building and connected to the net.
CPU and Memory are normal and there are no strange messages in the logs.
Any suggestions what it can be? I'm kinda lost.
NicP
Ok, tried one last thing, and it apparently  worked. We use Cisco ISE login on the switches and I did not yet added this new switch to ISE. Apparently the switch configuration mode get slowed down when the ISE server is ignoring the switch. Enabled mode does not show this behavior, and before adding it to ISE i logged into the switch with a local backup account and experienced this.
It still is weird behavior.
NicP
