01-13-2016 02:33 PM - edited 03-08-2019 03:23 AM
Hello All,
I'm not sure if this is the correct location to be posting this, but has the HSRP functionality been removed from the latest IOS?
Solved! Go to Solution.
01-13-2016 02:55 PM
Hi Blake,
HSRP has not been removed from the IOS, however on the 4500 it is dependant on the type of license tht you're using. Only IP Base and Enterprise Services will support it.
Please see the following link for further reference:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/ol-38xe-4500e.html
Julio
01-14-2016 08:28 PM
Hello Blake,
It seems your switch is running LAN Base image which don't support HSRP functionality.
As stated only IP base and Enterprise image support HSRP functionality.
Hope it Helps..
-GI
01-13-2016 02:55 PM
Hi Blake,
Julio
01-13-2016 05:16 PM
Can you get the output of show version from your box? And We can tell you the reason for the same?
01-14-2016 08:29 AM
It looks like we have the evaluation license applied, and are missing the IP base license that was suppose to come along with it. :(
01-14-2016 11:22 AM
speak with the resller you purchase device off they should have a record of the pak number and you will be able to retrieve that way
01-14-2016 10:36 AM
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.01.00.SG RELEASE )
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 10-Sep-10 04:08 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
Image text-base: 0x1009E954, data-base: 0x13DC4550
ROM: 15.0(1r)SG1
Jawa Revision 7, Snowtrooper Revision 0x0.0x15
YC-CORE1-NEW uptime is 3 weeks, 1 day, 23 hours, 54 minutes
System image file is "bootflash:cat4500e-universalk9.SPA.03.01.00.SG.150-1.XO.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Information for 'WS-X45-SUP7-E'
License Level: lanbase Type: Default. No valid license found.
Next reboot license Level: lanbase
cisco WS-C4506-E (MPC8572) processor (revision 8) with 786516K/16384K bytes of memory.
Processor board ID FXS1825Q1SF
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from PowerUp
29 Virtual Ethernet interfaces
84 Gigabit Ethernet interfaces
10 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
01-14-2016 08:28 PM
Hello Blake,
Hope it Helps..
-GI
