Cisco 4506 with WS-4013 supervisor 2 Plus using 80% memory!!!
Network_Team_2
I have 10 Cisco 4506 with ws-4013 supervisor 3 plus. My Solarwinds is stating 80% used.... should i be concerned.
I have 802.1x and VOIP running on all switches....
Please can you help point me in the correct direction for investigating.
9 Replies 9
Amit Singh
Could you Please paste the output of " show proc cpu " and " show proc mem".
Please see below
show processes cpu
CPU utilization for five seconds: 30%/1%; one minute: 31%; five minutes: 31%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1     2407536  20856780        115  0.00%  0.00%  0.00%   0 Chunk Manager
   2        6484   1388857          4  0.00%  0.00%  0.00%   0 Load Meter
   3           0         1          0  0.00%  0.00%  0.00%   0 CEF RP IPC Backg
   4           0         1          0  0.00%  0.00%  0.00%   0 Deferred Events
   5           0         1          0  0.00%  0.00%  0.00%   0 Retransmission o
   6           0         1          0  0.00%  0.00%  0.00%   0 IPC ISSU Receive
   7    26636368   1872211      14227  0.00%  0.40%  0.45%   0 Check heaps
   8         404      1341        301  0.00%  0.00%  0.00%   0 Pool Manager
   9           0         2          0  0.00%  0.00%  0.00%   0 Timers
  10           0         2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  11           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  12           0         1          0  0.00%  0.00%  0.00%   0 ifIndex Receive
  13           8        69        115  0.00%  0.00%  0.00%   0 EEM ED Syslog
  14        2308    123274         18  0.00%  0.00%  0.00%   0 ARP Input
  15           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  16           0        24          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  17      389440     23155      16818  0.00%  0.02%  0.00%   0 AAA high-capacit
  18           0         1          0  0.00%  0.00%  0.00%   0 Policy Manager
  19         120        15       8000  0.00%  0.00%  0.00%   0 Entity MIB API
  20           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  21         224    115746          1  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  22           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  23      107492   6914527         15  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  24           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  25       97204   6914533         14  0.00%  0.00%  0.00%   0 IPC Deferred Por
  26           0         1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  27           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  28           0         1          0  0.00%  0.00%  0.00%   0 client_entity_se
  29           0         1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  30           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  31      145164   6914524         20  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  32       95876   6914493         13  0.00%  0.00%  0.00%   0 GraphIt
  33           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  34       85340   5590887         15  0.00%  0.00%  0.00%   0 Net Background
  35    70736628  13885343       5094  1.03%  1.01%  1.01%   0 IDB Work
  36           0        73          0  0.00%  0.00%  0.00%   0 Logger
  37      142000   6914489         20  0.07%  0.00%  0.00%   0 TTY Background
  38     7884104   8521405        925  0.15%  0.11%  0.11%   0 Per-Second Jobs
  39     6041192    231364      26111  0.00%  0.05%  0.05%   0 Per-minute Jobs
  40          96         5      19200  0.00%  0.00%  0.00%   0 PrstVbl
  41          32        14       2285  0.00%  0.00%  0.00%   0 IF-MGR control p
  42          20      1270         15  0.00%  0.00%  0.00%   0 IF-MGR event pro
  43           0         1          0  0.00%  0.00%  0.00%   0 ISSU PROCESS IPC
  44           0         1          0  0.00%  0.00%  0.00%   0 PrstVbl IPC Msg
  45           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track HA
  46   8449515441459529921        578 17.67% 17.53% 17.38%   0 Cat4k Mgmt HiPri
  47   411176468 230990354       1780  6.15%  8.10%  8.32%   0 Cat4k Mgmt LoPri
  48      142336  24757718          5  0.00%  0.00%  0.00%   0 Galios Reschedul
  49           0         1          0  0.00%  0.00%  0.00%   0 IOS ACL Helper
  50           8         3       2666  0.00%  0.00%  0.00%   0 rf task
  51           0         1          0  0.00%  0.00%  0.00%   0 RF High Priority
  52          12        86        139  0.00%  0.00%  0.00%   0 Net Input
  53      803960   2282233        352  0.00%  0.04%  0.05%   0 Compute load avg
  54           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  55           4       182         21  0.00%  0.00%  0.00%   0 Transport Port A
  56       57080   2079542         27  0.00%  0.00%  0.00%   0 HC Counter Timer
  57           0         1          0  0.00%  0.00%  0.00%   0 SFF8472
  58           8        16        500  0.00%  0.00%  0.00%   0 Collection proce
  59           0         2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
  60           0         2          0  0.00%  0.00%  0.00%   0 REP Topology cha
  61       21868    585860         37  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
  62       45476   1661488         27  0.00%  0.00%  0.00%   0 802.1x Accountin
  63       41976    156583        268  0.00%  0.00%  0.00%   0 802.1x MDA Aging
  64      677368   1382379        490  0.00%  0.00%  0.00%   0 MAB Framework
  65         148       538        275  0.00%  0.00%  0.00%   0 802.1x switch
  66      173600   4005701         43  0.00%  0.00%  0.00%   0 DTP Protocol
  67     2063672   6945152        297  0.07%  0.01%  0.00%   0 EAP Framework
  68        4368    115747         37  0.00%  0.00%  0.00%   0 Port-Security
  69           0         2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  70       34752   7003603          4  0.07%  0.00%  0.00%   0 Ethernet Timer C
  71           0         2          0  0.00%  0.00%  0.00%   0 EFP Errd
  72        2480    694423          3  0.00%  0.00%  0.00%   0 Ethchnl
  73       77240   6945581         11  0.00%  0.02%  0.00%   0 UDLD
  74           0         2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
  75           0         2          0  0.00%  0.00%  0.00%   0 ARP HA
  76           0         1          0  0.00%  0.00%  0.00%   0 Switch Backup In
  77         156    115746          1  0.00%  0.00%  0.00%   0 MMN bkgrd proces
  78      465956    780062        597  0.00%  0.00%  0.00%   0 AAA Server
  79      440228   1065659        413  0.00%  0.00%  0.00%   0 AAA ACCT Proc
  80           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
  81           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
  82           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
  83          96     23810          4  0.00%  0.00%  0.00%   0 IP Admin SM Proc
  84     2550304  24288929        104  0.23%  0.17%  0.17%   0 CDP Protocol
  85        9984     13154        759  0.00%  0.00%  0.00%   0 SpanTree Helper
  87           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
  88        5700     57874         98  0.00%  0.00%  0.00%   0 DHCP Snooping
  89           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
  90           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
  91     2455132  15346298        159  0.15%  0.09%  0.08%   0 IP Input
  92           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
  93       55848  13534520          4  0.00%  0.00%  0.00%   0 IP ARP Track
  94           0        13          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
  95           0         1          0  0.00%  0.00%  0.00%   0 IPv6 Echo event
  96         112       348        321  0.79%  0.12%  0.02%   1 Virtual Exec
  97   110193640 271485348        405  1.43%  1.51%  1.53%   0 Spanning Tree
  98       10160    158991         63  0.00%  0.00%  0.00%   0 CEF background p
  99           0         1          0  0.00%  0.00%  0.00%   0 IP IRDP
100           0         3          0  0.00%  0.00%  0.00%   0 XDR mcast
101           0         1          0  0.00%  0.00%  0.00%   0 IPC LC Message H
102           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Ping Back
103         228     59605          3  0.00%  0.00%  0.00%   0 XDR RP backgroun
104           0         1          0  0.00%  0.00%  0.00%   0 XDR RP Test Back
105         204     86811          2  0.00%  0.00%  0.00%   0 Cluster L2
106        2680    694482          3  0.00%  0.00%  0.00%   0 Cluster RARP
107         188      8790         21  0.00%  0.00%  0.00%   0 TCP Timer
108          64       173        369  0.00%  0.00%  0.00%   0 TCP Protocols
109           0         1          0  0.00%  0.00%  0.00%   0 COPS
110           0         1          0  0.00%  0.00%  0.00%   0 Socket Timers
111          96     23879          4  0.00%  0.00%  0.00%   0 HTTP CORE
112           0         1          0  0.00%  0.00%  0.00%   0 Probe Input
113           0         1          0  0.00%  0.00%  0.00%   0 RARP Input
114           0         2          0  0.00%  0.00%  0.00%   0 REP LSL Proc
115           0         2          0  0.00%  0.00%  0.00%   0 REP BPA/EPA Proc
116           0         1          0  0.00%  0.00%  0.00%   0 802.1x Critical
117        3980     16598        239  0.00%  0.00%  0.00%   0 L2MM
118      115900   1199430         96  0.00%  0.00%  0.00%   0 MRD
119       42788    642672         66  0.00%  0.00%  0.00%   0 IGMPSN
120        3012     15263        197  0.00%  0.00%  0.00%   0 MLDSN L2MCM
121           0         1          0  0.00%  0.00%  0.00%   0 MRD
122           0         1          0  0.00%  0.00%  0.00%   0 MLD_SNOOP
123           0         2          0  0.00%  0.00%  0.00%   0 L2TRACE SERVER
124           0         1          0  0.00%  0.00%  0.00%   0 IGMPSN-HA
125           0         1          0  0.00%  0.00%  0.00%   0 DHCP Snooping HA
126     7063848  46645637        151  0.23%  0.23%  0.23%   0 LLDP Protocol
127           0         1          0  0.00%  0.00%  0.00%   0 HSRP HA
128       21616    236895         91  0.00%  0.00%  0.00%   0 IP Background
129        2396    115760         20  0.00%  0.00%  0.00%   0 IP RIB Update
130      613432  11100058         55  0.00%  0.01%  0.00%   0 CEF: IPv4 proces
131           0         6          0  0.00%  0.00%  0.00%   0 ADJ background
132           0         1          0  0.00%  0.00%  0.00%   0 CFMPAL Process
133           0         1          0  0.00%  0.00%  0.00%   0 EM Background Pr
134          36       273        131  0.00%  0.00%  0.00%   0 LOCAL AAA
135           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
136           0         2          0  0.00%  0.00%  0.00%   0 LINE AAA
138           0         2          0  0.00%  0.00%  0.00%   0 TPLUS
139           0         2          0  0.00%  0.00%  0.00%   0 VTPMIB EDIT BUFF
140           0         2          0  0.00%  0.00%  0.00%   0 DHCP Security He
141           0         1          0  0.00%  0.00%  0.00%   0 DiagCard1/-1
142           0         1          0  0.00%  0.00%  0.00%   0 DiagCard2/-1
143           0         1          0  0.00%  0.00%  0.00%   0 DiagCard3/-1
144           0         1          0  0.00%  0.00%  0.00%   0 DiagCard5/-1
145           0         1          0  0.00%  0.00%  0.00%   0 DiagCard6/-1
146     2070708  71580159         28  0.07%  0.07%  0.07%   0 PM Callback
147          16         8       2000  0.00%  0.00%  0.00%   0 VLAN Manager
149        2872    572910          5  0.00%  0.00%  0.00%   0 dhcp snooping sw
150           4         9        444  0.00%  0.00%  0.00%   0 VTP Trap Process
152        5408     11611        465  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
153           0         1          0  0.00%  0.00%  0.00%   0 Syslog Traps
154          24        86        279  0.00%  0.00%  0.00%   0 Syslog
155           0         4          0  0.00%  0.00%  0.00%   0 SPAN switch
156           4        57         70  0.00%  0.00%  0.00%   0 EEM Server
157           0         2          0  0.00%  0.00%  0.00%   0 EEM Policy Direc
158           0         2          0  0.00%  0.00%  0.00%   0 EEM ED CLI
159           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Config
160           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Counter
161           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Env
162           0         3          0  0.00%  0.00%  0.00%   0 EM ED GOLD
163           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Interface
164           0         3          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
165           0         3          0  0.00%  0.00%  0.00%   0 EEM ED None
166           0         3          0  0.00%  0.00%  0.00%   0 EEM ED OIR
167           0         2          0  0.00%  0.00%  0.00%   0 EEM ED RF
168           0         3          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
169           0         2          0  0.00%  0.00%  0.00%   0 EEM ED Snmp_Prox
170           0         3          0  0.00%  0.00%  0.00%   0 EEM ED Test
171        1752    215903          8  0.00%  0.00%  0.00%   0 EEM ED Timer
172          16      1052         15  0.00%  0.00%  0.00%   0 BACK CHECK
173           0         1          0  0.00%  0.00%  0.00%   0  CHKPT rcv MSG p
174           0         2          0  0.00%  0.00%  0.00%   0 cpf_process_msg_
175           0         1          0  0.00%  0.00%  0.00%   0 cpf_process_ipcQ
176     2277252   5122867        444  0.00%  0.01%  0.00%   0 Dot1x Authentica
177      692852   6432057        107  0.00%  0.00%  0.00%   0 Dot1x Authentica
178      312984   6175468         50  0.00%  0.00%  0.00%   0 LACP Protocol
179           0         5          0  0.00%  0.00%  0.00%   0 SNMP Timers
180     4325596  10659715        405  0.00%  0.06%  0.05%   0 IP SNMP
181      978004   3622972        269  0.00%  0.01%  0.00%   0 PDU DISPATCHER
182     5492896   3944323       1392  0.00%  0.08%  0.07%   0 SNMP ENGINE
183           0         2          0  0.00%  0.00%  0.00%   0 IP SNMPV6
184           0         1          0  0.00%  0.00%  0.00%   0 SNMP ConfCopyPro
185           0         1          0  0.00%  0.00%  0.00%   0 SNMP Traps
186     4293488 217435843         19  0.07%  0.09%  0.10%   0 RADIUS
187       41364   7224036          5  0.00%  0.00%  0.00%   0 NTP
188       80164   3462415         23  0.00%  0.00%  0.00%   0 System polling
show processes memory
Processor Pool Total:  226857300 Used:  167913680 Free:   58943620
PID TTY  Allocated      Freed    Holding    Getbufs    Retbufs Process
   0   0  126647500    8008676  110202280          0          0 *Init*
   0   0      12756    9116152      12756          0          0 *Sched*
   0   0  217093392  191301080   21250008     388268          0 *Dead*
   1   0   24876068  979570620      79616          0          0 Chunk Manager
   2   0        180        180      29984          0          0 Load Meter
   3   0        216          0      33192          0          0 CEF RP IPC Backg
   4   0          0          0      32924          0          0 Deferred Events
   5   0          0          0      32924          0          0 Retransmission o
   6   0          0          0      32924          0          0 IPC ISSU Receive
   7   0          0        400      32924          0          0 Check heaps
   8   0          0   22573724      32924          0    9861560 Pool Manager
   9   0        180        180      32924          0          0 Timers
  10   0        180        180      32924          0          0 Serial Backgroun
  11   0          0          0      50924          0          0 Crash writer
  12   0          0          0      32924          0          0 ifIndex Receive
  13   0     230560          0     266484      99792          0 EEM ED Syslog
  14   0     223684       7584     249424          0          0 ARP Input
  15   0          0          0      32924          0          0 CEF MIB API
  16   0          0          0      32924          0          0 AAA_SERVER_DEADT
  17   0        180        180      32924          0          0 AAA high-capacit
  18   0          0          0      38924          0          0 Policy Manager
  19   0     492984     654508     288040          0      93808 Entity MIB API
  20   0          0          0      32924          0          0 IFS Agent Manage
  21   0          0          0      32924          0          0 IPC Dynamic Cach
  22   0          0          0      32924          0          0 IPC Zone Manager
  23   0          0          0      32924          0          0 IPC Periodic Tim
  24   0          0          0      32924          0          0 IPC Managed Time
  25   0          0          0      32924          0          0 IPC Deferred Por
  26   0       1688          0      34612          0          0 IPC Seat Manager
  27   0          0          0      32924          0          0 IPC Session Serv
  28   0          0          0      32924          0          0 client_entity_se
  29   0          0          0      32924          0          0 SERIAL A'detect
  30   0          0          0      32924          0          0 ARP Snoop
  31   0          0          0      32924          0          0 Dynamic ARP Insp
  32   0        180        180      32924          0          0 GraphIt
  33   0          0          0      32924          0          0 Critical Bkgnd
  34   0      66804          0      39880          0          0 Net Background
  35   0 2959777700 2959777460      39164          0          0 IDB Work
  36   0        180        180      38924          0          0 Logger
  37   0        180       2620      35924          0        756 TTY Background
  38   0   58649540   58649540      32924          0          0 Per-Second Jobs
  39   0       1780          0      32924        756          0 Per-minute Jobs
  40   0        908        908      32992          0          0 PrstVbl
  41   0      16288     327900      49212          0          0 IF-MGR control p
  42   0          0          0      32924          0          0 IF-MGR event pro
  43   0          0          0      32924          0          0 ISSU PROCESS IPC
  44   0          0          0      32924          0          0 PrstVbl IPC Msg
  45   0        180        180      35924          0          0 IP Host Track HA
  46   0 1685303740  735785008    1101416       2268          0 Cat4k Mgmt HiPri
  47   0    1541340     265920     299256          0          0 Cat4k Mgmt LoPri
  48   0          0          0      32924          0          0 Galios Reschedul
  49   0          0          0      32924          0          0 IOS ACL Helper
  50   0     212904          0     114132          0          0 rf task
  51   0          0          0      32924          0          0 RF High Priority
  52   0          0          0      32924          0          0 Net Input
  53   0        180        180      32924          0          0 Compute load avg
  54   0          0          0      32924          0          0 AggMgr Process
  55   0          0      23276      32924          0          0 Transport Port A
  56   0          0          0      32924          0          0 HC Counter Timer
  57   0          0          0      32924          0          0 SFF8472
  58   0        468       1424      39140          0          0 Collection proce
  59   0        180        180      35924          0          0 Ethernet OAM Pro
  60   0        180        180      32924          0          0 REP Topology cha
  61   0        180        180      32924          0          0 Dot1x Mgr Proces
  62   0  980281584  980281584      35924          0          0 802.1x Accountin
  63   0        180        180      32924          0          0 802.1x MDA Aging
  64   0 1605886952  663187892   24159256          0          0 MAB Framework
  65   0        580      43920      33504          0          0 802.1x switch
  66   0       2892        180      35636          0          0 DTP Protocol
  67   0  687444180 1646516960    1343856          0          0 EAP Framework
  68   0        216          0      33140          0          0 Port-Security
  69   0        180        180      38924          0          0 Ethernet CFM
  70   0        180        180      38924          0          0 Ethernet Timer C
  71   0        180        180      32924          0          0 EFP Errd
  72   0        180        180      32924          0          0 Ethchnl
  73   0        472        180      33216          0          0 UDLD
  74   0        180        180      35924          0          0 IP Host Track Pr
  75   0          0          0      32924          0          0 ARP HA
  76   0      81352          0     114276          0          0 Switch Backup In
  77   0          0          0      32924          0          0 MMN bkgrd proces
  78   0 1303752436   31502344      36364    2930256          0 AAA Server
  79   0  676167896          0      36356      24948          0 AAA ACCT Proc
  80   0          0          0      32924          0          0 ACCT Periodic Pr
  81   0          0          0      32924          0          0 AAA System Acct
  82   0          0          0      32924          0          0 Auth-proxy AAA B
  83   0          0          0      32924          0          0 IP Admin SM Proc
  84   0  193750112  193714832      71156          0          0 CDP Protocol
  85   0    6368064    4157664      32924          0          0 SpanTree Helper
  87   0        204        204      32924          0          0 AAA Dictionary R
  88   0          0          0      32924          0          0 DHCP Snooping
  89   0        180        180      35924          0          0 EAPoUDP Process
  90   0        456        180      39200          0          0 CEF switching ba
  91   0     121348      14448      40264          0          0 IP Input
  92   0          0          0      32924          0          0 ICMP event handl
  93   0        180        180      35924          0          0 IP ARP Track
  94   0        944        180      39276          0          0 ADJ resolve proc
  95   0          0          0      32924          0          0 IPv6 Echo event
  96   1      21812      19220      63828          0          0 Virtual Exec
  97   0    2300720      59988      33140          0          0 Spanning Tree
  98   0        568        516      39140          0          0 CEF background p
  99   0          0          0      35924          0          0 IP IRDP
100   0          0          0      32924          0          0 XDR mcast
101   0          0          0      32924          0          0 IPC LC Message H
102   0          0          0      32924          0          0 XDR RP Ping Back
103   0          0          0      32924          0          0 XDR RP backgroun
104   0          0          0      32924          0          0 XDR RP Test Back
105   0        180        180      32924          0          0 Cluster L2
106   0          0          0      32924          0          0 Cluster RARP
107   0       1136      13244      38924          0          0 TCP Timer
108   0    3363908          0      38924          0          0 TCP Protocols
109   0          0          0      50924          0          0 COPS
110   0          0          0      32924          0          0 Socket Timers
111   0       6808       4368      38212          0          0 HTTP CORE
112   0          0          0      32924          0          0 Probe Input
113   0          0          0      32924          0          0 RARP Input
114   0        180        180      32924          0          0 REP LSL Proc
115   0      14944        180      47688          0          0 REP BPA/EPA Proc
116   0          0          0      32924          0          0 802.1x Critical
117   0      54728    3131636      86664          0          0 L2MM
118   0       1468          0      33296          0          0 MRD
119   0       5068       2976      35016          0          0 IGMPSN
120   0    6858304   10414792      91548          0          0 MLDSN L2MCM
121   0          0          0      32924          0          0 MRD
122   0          0          0      32924          0          0 MLD_SNOOP
123   0       2848        180      35592          0          0 L2TRACE SERVER
124   0          0          0      32924          0          0 IGMPSN-HA
125   0          0          0      32924          0          0 DHCP Snooping HA
126   0     503680     379336     160268          0          0 LLDP Protocol
127   0          0          0      32924          0          0 HSRP HA
128   0      10188          0      46112          0          0 IP Background
129   0     217144       1532     250908          0          0 IP RIB Update
130   0     243436        332     248888          0          0 CEF: IPv4 proces
131   0        216          0      33140          0          0 ADJ background
132   0          0          0      32924          0          0 CFMPAL Process
133   0          0          0      32924          0          0 EM Background Pr
134   0      58308      72984      32924          0          0 LOCAL AAA
135   0        180        180      32924          0          0 ENABLE AAA
136   0        180        180      32924          0          0 LINE AAA
138   0       2056        180      34800          0          0 TPLUS
139   0        180        180      32924          0          0 VTPMIB EDIT BUFF
140   0        180        180      32924          0          0 DHCP Security He
141   0          0          0      32924          0          0 DiagCard1/-1
142   0          0          0      32924          0          0 DiagCard2/-1
143   0          0          0      32924          0          0 DiagCard3/-1
144   0          0          0      32924          0          0 DiagCard5/-1
145   0          0          0      32924          0          0 DiagCard6/-1
146   0    5660336   13299852      42444          0          0 PM Callback
147   0      91780      76956      45716       2340          0 VLAN Manager
149   0        180        180      32924          0          0 dhcp snooping sw
150   0        180        640      32924          0          0 VTP Trap Process
152   0    5893748   13302556      32924          0          0 AAA SEND STOP EV
153   0          0          0      32924          0          0 Syslog Traps
154   0      18980      16524      41380          0          0 Syslog
155   0        180        180      32924          0          0 SPAN switch
156   0     138196          0     171120          0          0 EEM Server
157   0       9676        832      41768          0          0 EEM Policy Direc
158   0       3724          0      39648          0          0 EEM ED CLI
159   0       3724          0      39648          0          0 EEM ED Config
160   0       3724          0      39648          0          0 EEM ED Counter
161   0       3724          0      39648          0          0 EEM ED Env
162   0       3724          0      39648          0          0 EM ED GOLD
163   0       3724          0      39648          0          0 EEM ED Interface
164   0       3724          0      39648          0          0 EEM ED IOSWD
165   0       3724          0      39648          0          0 EEM ED None
166   0       3724          0      39648          0          0 EEM ED OIR
167   0       3820          0      39744          0          0 EEM ED RF
168   0       3724          0      39648          0          0 EEM ED SNMP
169   0       3724          0      39648          0          0 EEM ED Snmp_Prox
170   0       3724          0      39648          0          0 EEM ED Test
171   0       3724          0      39648          0          0 EEM ED Timer
172   0          0          0      32924          0          0 BACK CHECK
173   0          0          0      32924          0          0  CHKPT rcv MSG p
174   0          0          0      32924          0          0 cpf_process_msg_
175   0          0          0      32924          0          0 cpf_process_ipcQ
176   0  498544044 2939250256     852044          0          0 Dot1x Authentica
177   0       9856        196      42584          0          0 Dot1x Authentica
178   0     133324      28044      93604          0          0 LACP Protocol
179   0          0          0      32924          0          0 SNMP Timers
180   0  269143012  269142088      39848          0          0 IP SNMP
181   0 3632746488          0      50176          0          0 PDU DISPATCHER
182   0 1750520128 1088028732     298260          0          0 SNMP ENGINE
183   0       1056        180      39800          0          0 IP SNMPV6
184   0          0          0      38924          0          0 SNMP ConfCopyPro
185   0          0          0      38924          0          0 SNMP Traps
186   0 1185157272  605223716     269932    6806268          0 RADIUS
187   0        548        180      33292          0          0 NTP
188   0          0          0      29948          0          0 System polling
                                167864976 Total
Hmmmm ... That's too long.  How about "sh proc cpu | ex 0.00"?
show processes cpu sorted | ex 0.00
CPU utilization for five seconds: 27%/1%; one minute: 31%; five minutes: 31%
  46   8524145001472549557        578 16.62% 17.42% 17.54%   0 Cat4k Mgmt HiPri
  47   414827684 233004840       1780  6.07%  7.70%  8.14%   0 Cat4k Mgmt LoPri
  97   111143952 273938900        405  1.91%  1.86%  1.86%   0 Spanning Tree
  35    71356496  14007914       5094  1.03%  1.00%  1.01%   0 IDB Work
126     7126616  47059874        151  0.23%  0.23%  0.23%   0 LLDP Protocol
  84     2573344  24516749        104  0.23%  0.17%  0.17%   0 CDP Protocol
  38     7953492   8594931        925  0.23%  0.11%  0.11%   0 Per-Second Jobs
186     4329208 219346283         19  0.15%  0.14%  0.15%   0 RADIUS
  96         216       666        324  0.07%  0.23%  0.06%   1 Virtual Exec
  53      811016   2302442        352  0.07%  0.04%  0.05%   0 Compute load avg
146     2090208  72225087         28  0.07%  0.07%  0.07%   0 PM Callback
Please paste the outputs of the follwoing:
>> sh proc cpu sorted | ex 0.00
>>show platform cpu packet statistics all | beg Packets Received by Packet Queue
>> sh platform health
Swati
ket statistics all | begin Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Esmp                         694356061       149       130        97         85
L2/L3Control                 835303938       179       157       118        106
Host Learning                  5560199         1         0         0          0
L3 Fwd High                          0         0         0         0          0
L3 Fwd Medium                        0         0         0         0          0
L3 Fwd Low                          10         0         0         0          0
L2 Fwd High                          0         0         0         0          0
L2 Fwd Medium                        0         0         0         0          0
L2 Fwd Low                        2054         0         0         0          0
L3 Rx High                         926         0         0         0          0
L3 Rx Low                     15230791         5         0         0          0
RPF Failure                          0         0         0         0          0
ACL fwd(snooping)                    0         0         0         0          0
ACL log, unreach                     0         0         0         0          0
ACL sw processing                    0         0         0         0          0
MTU Fail/Invalid                     0         0         0         0          0
Packets Dropped by Packet Queue
Esmp                                 0         0         0         0          0
L2/L3Control                         0         0         0         0          0
Host Learning                        0         0         0         0          0
L3 Fwd Low                           0         0         0         0          0
L2 Fwd Low                           0         0         0         0          0
L3 Rx High                           0         0         0         0          0
L3 Rx Low                            0         0         0         0          0
Packets Transmitted from CPU per Output Interface
Interface              Total           5 sec avg 1 min avg 5 min avg 1 hour avg
Gi2/1                                0         0         0         0          0
Gi2/2                                0         0         0         0          0
Gi2/3                                0         0         0         0          0
Gi2/4                                0         0         0         0          0
Gi2/5                                0         0         0         0          0
Gi2/6                                0         0         0         0          0
Gi3/1                                0         0         0         0          0
Gi3/2                                0         0         0         0          0
Gi3/3                                0         0         0         0          0
Gi3/4                                0         0         0         0          0
Gi3/5                                0         0         0         0          0
Gi3/6                                0         0         0         0          0
Gi3/7                                0         0         0         0          0
Gi3/8                                0         0         0         0          0
Gi3/9                                0         0         0         0          0
Gi3/10                               0         0         0         0          0
Gi3/11                               0         0         0         0          0
Gi3/12                               0         0         0         0          0
Gi3/13                               0         0         0         0          0
Gi3/14                               0         0         0         0          0
Gi3/15                               0         0         0         0          0
Gi3/16                               0         0         0         0          0
Gi3/17                               0         0         0         0          0
Gi3/18                               0         0         0         0          0
Gi3/19                               0         0         0         0          0
Gi3/20                               0         0         0         0          0
Gi3/21                               0         0         0         0          0
Gi3/22                               0         0         0         0          0
Gi3/23                               0         0         0         0          0
Gi3/24                               0         0         0         0          0
Gi3/25                               0         0         0         0          0
Gi3/26                               0         0         0         0          0
Gi3/27                               0         0         0         0          0
Gi3/28                               0         0         0         0          0
Gi3/29                               0         0         0         0          0
Gi3/30                               0         0         0         0          0
Gi3/31                               0         0         0         0          0
Gi3/32                               0         0         0         0          0
Gi3/33                               0         0         0         0          0
Gi3/34                               0         0         0         0          0
Gi3/35                               0         0         0         0          0
Gi3/36                               0         0         0         0          0
Gi3/37                               0         0         0         0          0
Gi3/38                               0         0         0         0          0
Gi3/39                               0         0         0         0          0
Gi3/40                               0         0         0         0          0
Gi3/41                               0         0         0         0          0
Gi3/42                               0         0         0         0          0
Gi3/43                               0         0         0         0          0
Gi3/44                               0         0         0         0          0
Gi3/45                               0         0         0         0          0
Gi3/46                               0         0         0         0          0
Gi3/47                               0         0         0         0          0
Gi3/48                               0         0         0         0          0
Gi5/1                                0         0         0         0          0
Gi5/2                                0         0         0         0          0
Gi5/3                                0         0         0         0          0
Gi5/4                                0         0         0         0          0
Gi5/5                                0         0         0         0          0
Gi5/6                                0         0         0         0          0
Gi5/7                                0         0         0         0          0
Gi5/8                                0         0         0         0          0
Gi5/9                                0         0         0         0          0
Gi5/10                               0         0         0         0          0
Gi5/11                               0         0         0         0          0
Gi5/12                               0         0         0         0          0
Gi5/13                               0         0         0         0          0
Gi5/14                               0         0         0         0          0
Gi5/15                               0         0         0         0          0
Gi5/16                               0         0         0         0          0
Gi5/17                               0         0         0         0          0
Gi5/18                               0         0         0         0          0
Gi5/19                               0         0         0         0          0
Gi5/20                               0         0         0         0          0
Gi5/21                               0         0         0         0          0
Gi5/22                               0         0         0         0          0
Gi5/23                               0         0         0         0          0
Gi5/24                               0         0         0         0          0
Gi5/25                               0         0         0         0          0
Gi5/26                               0         0         0         0          0
Gi5/27                               0         0         0         0          0
Gi5/28                               0         0         0         0          0
Gi5/29                               0         0         0         0          0
Gi5/30                               0         0         0         0          0
Gi5/31                               0         0         0         0          0
Gi5/32                               0         0         0         0          0
Gi5/33                               0         0         0         0          0
Gi5/34                               0         0         0         0          0
Gi5/35                               0         0         0         0          0
Gi5/36                               0         0         0         0          0
Gi5/37                               0         0         0         0          0
Gi5/38                               0         0         0         0          0
Gi5/39                               0         0         0         0          0
Gi5/40                               0         0         0         0          0
Gi5/41                               0         0         0         0          0
Gi5/42                               0         0         0         0          0
Gi5/43                               0         0         0         0          0
Gi5/44                               0         0         0         0          0
Gi5/45                               0         0         0         0          0
Gi5/46                               0         0         0         0          0
Gi5/47                               0         0         0         0          0
Gi5/48                               0         0         0         0          0
Gi6/1                                0         0         0         0          0
Gi6/2                                0         0         0         0          0
Gi6/3                                0         0         0         0          0
Gi6/4                                0         0         0         0          0
Gi6/5                                0         0         0         0          0
Gi6/6                                0         0         0         0          0
Gi6/7                                0         0         0         0          0
Gi6/8                                0         0         0         0          0
Gi6/9                                0         0         0         0          0
Gi6/10                               0         0         0         0          0
Gi6/11                               0         0         0         0          0
Gi6/12                               0         0         0         0          0
Gi6/13                               0         0         0         0          0
Gi6/14                               0         0         0         0          0
Gi6/15                               0         0         0         0          0
Gi6/16                               0         0         0         0          0
Gi6/17                               0         0         0         0          0
Gi6/18                               0         0         0         0          0
Gi6/19                               0         0         0         0          0
Gi6/20                               0         0         0         0          0
Gi6/21                               0         0         0         0          0
Gi6/22                               0         0         0         0          0
Gi6/23                               0         0         0         0          0
Gi6/24                               0         0         0         0          0
Gi6/25                               0         0         0         0          0
Gi6/26                               0         0         0         0          0
Gi6/27                               0         0         0         0          0
Gi6/28                               0         0         0         0          0
Gi6/29                               0         0         0         0          0
Gi6/30                               0         0         0         0          0
Gi6/31                               0         0         0         0          0
Gi6/32                               0         0         0         0          0
Gi6/33                               0         0         0         0          0
Gi6/34                               0         0         0         0          0
Gi6/35                               0         0         0         0          0
Gi6/36                               0         0         0         0          0
Gi6/37                               0         0         0         0          0
Gi6/38                               0         0         0         0          0
Gi6/39                               0         0         0         0          0
Gi6/40                               0         0         0         0          0
Gi6/41                               0         0         0         0          0
Gi6/42                               0         0         0         0          0
Gi6/43                               0         0         0         0          0
Gi6/44                               0         0         0         0          0
Gi6/45                               0         0         0         0          0
Gi6/46                               0         0         0         0          0
Gi6/47                               0         0         0         0          0
Gi6/48                               0         0         0         0          0
Gi1/1                                0         0         0         0          0
Gi1/2                                0         0         0         0          0
show platform health
                     %CPU   %CPU    RunTimeMax   Priority  Average %CPU  Total
                     Target Actual Target Actual   Fg   Bg 5Sec Min Hour  CPU
GalChassisVp-review    3.00   1.30     10    103  100  500    1   1    1  1309:55
S2w-JobEventSchedule  10.00   4.64     10      9  100  500    5   5    4  5058:45
Stub-JobEventSchedul  10.00   5.13     10     14  100  500    5   5    3  4464:16
Lj-poll                1.00   0.01      2      1  100  500    0   0    0  28:47
StatValueMan Update    1.00   0.08      1      1  100  500    0   0    0  136:45
Pim-review             0.10   0.00      1      1  100  500    0   0    0  9:09
Ebm-host-review        1.00   0.00      8      4  100  500    0   0    0  39:48
Ebm-host-util-review   1.00   0.00     10      0  100  500    0   0    0  0:13
Ebm-port-review        0.10   0.00      1      0  100  500    0   0    0  0:42
Protocol-aging-revie   0.20   0.00      2      0  100  500    0   0    0  0:02
EbmHostRedundancyMan   2.00   0.00     20      0  100  500    0   0    0  0:00
Acl-Flattener          1.00   0.00     10      3  100  500    0   0    0  0:00
IrmFibThrottler Thro   2.00   0.00      7      0  100  500    0   0    0  9:44
GalChassisVp Ondeman   2.00   0.00      2      0  100  500    0   0    0  0:00
KxAclPathMan create/   1.00   0.00     10      5  100  500    0   0    0  2:26
KxAclPathMan update    2.00   0.00     10      5  100  500    0   0    0  9:38
KxAclPathMan reprogr   1.00   0.00      2      0  100  500    0   0    0  0:00
TagMan-RecreateMtegR   1.00   0.00     10     18  100  500    0   0    0  0:00
K2CpuMan Review       30.00  11.12     30    104  100  500   12  11    8  10136:22
K2AccelPacketMan: Tx  10.00   1.87     20      1  100  500    2   1    1  1571:15
K2AccelPacketMan: Au   0.10   0.00      0      0  100  500    0   0    0  0:00
K2AclMan-labeledFlat   1.00   0.00     10      5  100  500    0   0    0  0:00
K2AclCamMan stale en   1.00   0.00     10      5  100  500    0   0    0  0:00
K2AclCamMan consolid   1.00   0.00     10      0  100  500    0   0    0  0:00
K2AclCamMan hw stats   3.00   0.08     10      5  100  500    0   0    0  581:01
K2AclCamMan kx stats   1.00   0.00     10      6  100  500    0   0    0  351:54
K2AclCamMan Audit re   1.00   0.00     10      5  100  500    0   0    0  322:52
K2AclPolicerTableMan   1.00   0.01     10      1  100  500    0   0    0  11:24
K2L2 Address Table R   2.00   0.00     12      5  100  500    1   1    0  978:44
K2L2 New Static Addr   2.00   0.00     10      0  100  500    0   0    0  0:03
K2L2 New Multicast A   2.00   0.00     10      5  100  500    0   0    0  2:04
K2L2 Dynamic Address   2.00   0.00     10      5  100  500    0   0    0  1:06
K2L2 Vlan Table Revi   2.00   0.00     12      9  100  500    0   0    0  2:40
K2PortMan Review       3.00   3.61     15     11  100  500    3   3    2  2980:39
Gigaport0 Review       0.40   0.02      4      3  100  500    0   0    0  12:28
Gigaport1 Review       0.40   0.02      4      3  100  500    0   0    0  12:30
Gigaport2 Review       0.40   0.02      4      3  100  500    0   0    0  12:26
Gigaport3 Review       0.40   0.02      4      3  100  500    0   0    0  13:15
Gigaport4 Review       0.40   0.02      4      3  100  500    0   0    0  12:47
Gigaport5 Review       0.40   0.01      4      3  100  500    0   0    0  13:51
Gigaport6 Review       0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport7 Review       0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport8 Review       0.40   0.00      4      3  100  500    0   0    0  12:32
Gigaport9 Review       0.40   0.00      4      3  100  500    0   0    0  13:53
Gigaport10 Review      0.40   0.00      4      3  100  500    0   0    0  12:30
Gigaport11 Review      0.40   0.00      4      3  100  500    0   0    0  12:26
Gigaport12 Review      0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport13 Review      0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport14 Review      0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport15 Review      0.40   0.00      4      0  100  500    0   0    0  0:00
Gigaport16 Review      0.40   0.08      4     51  100  500    0   0    0  84:31
Gigaport17 Review      0.40   0.09      4      3  100  500    0   0    0  84:46
Gigaport18 Review      0.40   0.10      4      3  100  500    0   0    0  87:46
Gigaport19 Review      0.40   0.09      4      3  100  500    0   0    0  87:33
Gigaport20 Review      0.40   0.07      4      3  100  500    0   0    0  82:09
Gigaport21 Review      0.40   0.09      4      3  100  500    0   0    0  82:25
Gigaport22 Review      0.40   0.08      4      7  100  500    0   0    0  81:34
Gigaport23 Review      0.40   0.08      4      9  100  500    0   0    0  82:42
Gigaport24 Review      0.40   0.00      4      3  100  500    0   0    0  13:05
Gigaport25 Review      0.40   0.00      4      3  100  500    0   0    0  12:40
Gigaport26 Review      0.40   0.00      4      3  100  500    0   0    0  12:58
Gigaport27 Review      0.40   0.00      4      3  100  500    0   0    0  12:47
Gigaport28 Review      0.40   0.00      4      3  100  500    0   0    0  12:26
Gigaport29 Review      0.40   0.00      4      3  100  500    0   0    0  12:33
Gigaport30 Review      0.40   0.00      4      3  100  500    0   0    0  12:32
Gigaport31 Review      0.40   0.00      4      3  100  500    0   0    0  12:55
K2Fib cam usage revi   2.00   0.00     15      0  100  500    0   0    0  0:00
K2Fib IrmFib Review    2.00   0.00     15      0  100  500    0   0    0  0:00
K2Fib AdjRepop Revie   2.00   0.00     15      0  100  500    0   0    0  0:00
K2Fib Vrf Unpunt Rev   2.00   0.00     15      0  100  500    0   0    0  9:42
K2Fib Consistency Ch   1.00   0.00      5      3  100  500    0   0    0  491:30
K2FibAdjMan Stats Re   2.00   0.06     10      4  100  500    0   0    0  133:13
K2FibAdjMan Host Mov   2.00   0.00     10      4  100  500    0   0    0  0:49
K2FibAdjMan Adj Chan   2.00   0.00     10      0  100  500    0   0    0  0:00
K2FibMulticast Signa   2.00   0.00     10      2  100  500    0   0    0  38:24
K2FibMulticast Entry   2.00   0.00     10      7  100  500    0   0    0  0:44
K2FibMulticast Irm M   2.00   0.00     10      0  100  500    0   0    0  0:00
K2FibFastDropMan Rev   2.00   0.00      7      0  100  500    0   0    0  0:00
K2FibPbr route map r   2.00   0.15     20      5  100  500    0   0    0  391:21
K2FibPbr flat acl pr   2.00   0.02     20      2  100  500    0   0    0  77:21
K2FibPbr consolidati   2.00   0.00     10      0  100  500    0   0    0  9:56
K2FibPerVlanPuntMan    2.00   0.00     15      3  100  500    0   0    0  0:00
K2FibWccpMan Service   2.00   0.00     20      0  100  500    0   0    0  0:00
K2FibWccpMan Cache E   2.00   0.00     20      0  100  500    0   0    0  0:00
K2FibWccpMan Redirec   2.00   0.00     20      0  100  500    0   0    0  0:00
K2FibWccpMan AdjRepo   2.00   0.00     20      0  100  500    0   0    0  0:00
K2FibFC Aging review   2.00   0.00     10      0  100  500    0   0    0  8:33
K2FibFC DelFlow revi   2.00   0.00     10      0  100  500    0   0    0  0:00
K2FibFC Adj review     2.00   0.00     10      0  100  500    0   0    0  8:32
K2FibFC overload/rel   2.00   0.00     10      0  100  500    0   0    0  2:48
K2MetStatsMan Review   2.00   0.02      5      3  100  500    0   0    0  469:32
K2FibMulticast MET S   2.00   0.00     10      0  100  500    0   0    0  0:00
K2QosDblMan Rate DBL   2.00   0.10      7      1  100  500    0   0    0  119:35
K2 VlanStatsMan Revi   2.00   0.25     15      2  100  500    0   0    0  353:05
K2 Packet Memory Dia   2.00   0.00     15      8  100  500    2   1    0  1045:26
K2 L2 Aging Table Re   2.00   0.06     20      3  100  500    0   0    0  177:27
K2PacketBufMonitor-P   3.00   2.86     10      1  100  500    3   3    2  2592:09
GbmHostTable Review    2.00   0.01      8      0  100  500    0   0    0  1:55
GbmHostTableUtilizat   2.00   0.00      8      0  100  500    0   0    0  0:00
GbmHostTableAging Re   2.00   0.00      8      0  100  500    0   0    0  2:52
RkiosPortMan Port Re   2.00   0.85     12     11  100  500    1   1    0  905:44
Rkios Module State R   4.00   0.03     40      2  100  500    0   0    0  34:18
Rkios Online Diag Re   4.00   0.02     40      1  100  500    0   0    0  29:27
RkiosIpPbr IrmPort R   2.00   0.06     10      3  100  500    0   0    0  62:42
RkiosIpWccp IrmWccpW   2.00   0.00     10      0  100  500    0   0    0  5:46
RkiosAclMan Review     3.00   0.05     30      1  100  500    0   0    0  61:29
MatMan Review          0.50   0.00      4      0  100  500    0   0    0  0:00
EthHoleLinecardMan(1   2.00   0.03     10      6  100  500    0   0    0  31:54
EthHoleLinecardMan(2   2.00   0.25     10      4  100  500    0   0    0  271:08
EthHoleLinecardMan(3   2.00   1.32     10      3  100  500    1   1    1  1614:02
EthHoleLinecardMan(5   2.00   1.23     10      3  100  500    1   1    1  1613:56
EthHoleLinecardMan(6   2.00   0.96     10      3  100  500    1   1    1  1616:08
GalLinecardDiag Mana   1.00   0.00     10      0  100  500    0   0    0  0:00
%CPU Totals          212.80  37.22
                       Allocation ceiling        Current allocation
                       kbytes    % in use        kbytes    % in use
Linecard 1's Store        258.00      12%           31.65      100%
Linecard 2's Store        258.00      12%           33.32      100%
Linecard 3's Store        258.00      87%          224.68      100%
Linecard 4's Store        258.00       0%            0.00        0%
Linecard 5's Store        258.00      87%          224.68      100%
Linecard 6's Store        258.00      87%          224.68      100%
TSM objects            ------------------        ------------------
PacketInfoItem            859.37       0%            4.03        0%
VbufNodes2400              80.50       0%            0.00        0%
VbufNodes1600              55.50       0%           12.14        0%
VbufNodes400              288.00       0%            8.43       33%
VbufNodes64                60.00       0%            4.68        0%
VbufNodes4200              68.37       0%            0.00        0%
PacketBufRaw            25219.50     100%        25219.50      100%
PacketBufRawJumbo         184.29     100%          184.29      100%
RkiosSysPacketBuf         250.00       0%            0.53        0%
Packet                   2079.42       2%           54.21       99%
MatEntrys                7680.00       0%            0.46      100%
MatEntryTableIterato        1.00       0%            0.03        0%
RkiosAclMan NamedGal       43.75       0%            0.00        0%
LpipAceListNode           192.00       0%            0.00        0%
Rkios Acl VlanMaps        128.00       0%            0.00        0%
Rkios Acl VlanMapEnt      859.37       0%            0.00        0%
Rkios EVC EFPs           1280.00       0%            0.00        0%
Rkios GBM BridgeDoma      256.00       0%            0.00        0%
Rkios GBM PseudoPort      768.00       0%            0.00        0%
Rkios QoS PolicyMaps      356.32       0%            0.15      100%
Rkios QoS ClassMaps       896.00       0%            0.19      100%
AclToIosFilterMapLis      384.00       0%            0.04      100%
Rkios QoS Policers        456.00       0%            0.00        0%
RkiosTableMap Galios        3.00       0%            0.00        0%
PimPhyports              1015.62      24%          250.85      100%
PimPorts                  906.25      31%          281.84      100%
PimModules                160.00       1%            3.12      100%
PimSlots                    5.00       2%            0.11      100%
PimChassis                 37.62       6%            2.35      100%
PimQuack                    0.35       0%            0.00        0%
EbmVlans                 4992.00       1%           75.56      100%
EbmVlanGroupEntrys       1920.00       0%            7.03       96%
EbmPorts                  312.00      30%           94.14      100%
EbmPortHostEntrys         384.00       0%            4.14       91%
EbmIeNodes                540.00       0%            5.27      100%
EbmPortVlanAclFeatur     2176.00       0%            0.00        0%
Ebm PV Maps               160.00       0%            0.00        0%
EbmSortedHostTableIt        1.75       0%            0.05        0%
EbmSortedGroupTableI        1.75       0%            0.05        0%
EbmHostRedundancyMan     1082.81       0%            0.00        0%
IrmVrfs                   315.00       0%            2.46      100%
IrmFibLoadBalances       1152.00       0%            0.00        0%
IrmFibAdjs               1920.00       0%            0.78       80%
IrmPortEtherAddrEntr      500.00       0%            0.00        0%
IrmFibEntries           12288.00       0%            0.89       78%
IrmMfibEntryMemMan       6656.00       0%            0.10      100%
IrmWccpMemMan              34.03       0%            0.00        0%
AclOp                    2048.00       0%            0.00        0%
AclOpAceSet              2559.96       0%            0.00        0%
AclClassifier            1280.00       0%            1.56      100%
AclFeature               2570.04       0%            2.07      100%
Acl                      1408.00       0%            1.71      100%
Ace24                    9215.85       0%            5.06      100%
Ace48                   15359.76       0%            0.00        0%
AceActionDescStorage     1023.98       0%            0.00        0%
AclListNode               256.00       0%            0.32       97%
AceListNode             25600.00       0%            0.52       29%
AclClassifierActionL     1152.00       0%            1.44       90%
AclLayerFeatureListN      512.00       0%            0.07       44%
AclClassifierListNod      256.00       0%            0.00        0%
TableMapMan NameToTa       27.00       0%            0.00        0%
TableMapAllocator         116.00       0%            0.00        0%
FlatAcl                   512.00       0%            0.29       10%
FlatAce24               10752.00       0%            3.19       23%
FlatAce48               16896.00       0%            0.00        0%
FlatAceActionListNod   281600.00       0%            2.75       31%
FlatAclOpSetStorage      3072.00       0%            0.00        0%
FlatAclCacheNode         4224.00       0%            0.25      100%
FlatAclListNode           256.00       0%            0.14        0%
QosFeatureClassifier      135.26       0%            1.09       99%
QosFeatureClassifier     2367.14       0%            2.18       99%
QosClassifierActionL      896.00       1%           15.14       99%
QosPortVlanAclFeatur     1152.00       0%            0.00        0%
QosEvcEfpAllocator       4352.00       0%            0.00        0%
QoS Policers             5624.00       0%            0.00        0%
MOL EVC EFPs            11264.00       0%            0.00        0%
EvcEfpEncapVlanRange     1024.00       0%            0.00        0%
MOL GBM BridgeDomain     2304.00       0%            0.00        0%
MOL GBM PseudoPort       6144.00       0%            0.00        0%
GbmSortedHostTableIt        1.62       0%            0.00        0%
GbmBridgeDomainHostE    16384.00       0%            0.00        0%
KxAclPath                1024.00       0%            4.37       99%
KxAclPathListNode         384.00       0%            0.00        0%
KxAclConstPathListNo      384.00       0%            0.92        0%
IndexCache                800.78       0%            0.00        0%
ConfigToHwAfMap           202.89       0%            0.00        0%
HwToCfgAceMap             767.98       0%            0.00        0%
CommandTables              48.00      21%           10.54      100%
K2FibWccpServiceGrou      162.53       0%            0.00        0%
K2FibPbrFlatRouteMap      481.57       0%            0.00        0%
K2FibPbrExpandedFlat     2304.00       0%            0.00        0%
K2FibPbrFlatRouteMap      320.00       0%            0.00        0%
K2FibVrfs                 152.00       0%            1.18      100%
K2 Netflow FPT Entri       11.97       0%            0.00        0%
K2TxPacket                384.00       0%            0.11        0%
K2TxPacketInfo            256.00       0%            1.48        0%
KxAclLabeledFlatAcl      3584.00       0%            0.21      100%
KxAclLabeledFlatAclE     3072.00       0%            0.09      100%
EbmVlanHostEntrys        2048.00       2%           93.25       65%
GalGbicEntrys              11.39       0%            0.00        0%
Event Nodes               128.00       0%            0.84       29%
Event Nodes               128.00       2%           14.28       25%
RkisoIpPbrRouteMaps        97.65       0%            0.00        0%
Rkios QoS EVC EFPs        768.00       0%            0.00        0%
IrmFlows                  384.00       0%            0.00        0%
K2AclMappingTableEnt      103.21       0%            0.01        0%
K2AclMappingTableEnt       68.81       0%            0.00        0%
K2AclTagPairSignatur     1536.00       0%            0.09      100%
TSM totals             530966.09       4%        26382.82       99%
sdheer
Hi Levent ,
From the outputs you pasted i see that the CPU is only at 27 %.
The problem of high CPU is dynamic innature in a sense that it could be troubleshooted only at the time when the issue is occurring.
Therefore take the follwoing outputs when the CPU is running high ,then we will be able to isolate the issue.
>> sh int | i line|rate|drops
>> sh platform health ( take it 2-3 times)
>> sh cpu packet statistics all
Kindly take these outputs and attched ina zip file to the post.
Swati
Please rate if you find above content useful
Hi Just to confirm the problem we are seeing is not high cpu but high memory at 80% all the time
Are you geeting any malloc failure or memeory fragmentation messages in the logs ?
Is there any issues like switch getting hung because of the high emory.
Paste the folllwoing outputs
>> show proc mem sorted
>> show proc mem statistics
Take the above outputs in interval of about 30 min thrice and paste it.
Swati
