Cisco 4507 SUP 7-E 1 gig module cpnversion cmd not supported?
m-abooali
Level 4
Level 4
I am trying to convert the 4 uplinks, by default at 10 gig to 4x 1 gig ports using:
Switch(config)# hw-module uplink select?
  gigabitethernet     Select the gigabit uplinks
  tengigabitethernet  Select the 10G uplinks
but the system doesn't recognize these commands!?
IOS: 15.1.1 SG
any help will be greatly appreciated.
Reagrds,
Masood
7 Replies 7
Reza Sharifi
Hi Masood,
I have not used 4500 before, but can check to see if you need to apply this command first?
hw-module uplink mode
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/46sg/command/reference/ch2a_ins.html#wp1631621
I will try that but I beleive I have already done that with no result. this process and command syntax was done on SUP 6 series with no problem but on this SUP 7 E, it just doesn't understand the command and deosn't provide the options needed after the "hw-module module # ...." after the Number for module the only option available is "logging"!?
Masood
Try:
# hw-module module 1 port-group gigabit
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/44sg/configuration/guide/sw_int.html
Inayath
*Plz rate all usefull posts.
None of thesew ocmmands shows up under the excec mode or conf t mode. I have attached a picture.
gscalia01
HI,
I'm having the same issue like you did i don't see the commands as well.
I need to configure the gigs for 1 Gig and i don't see any option is logging after hw-module module #
Were you able lt o fix the issue ? if so, what is the fix for it?
Jack
Did you ever figure this out?  I'm having the same problem.
gscalia01
I find out with the Sup7E there is no need for the command, it auto detects the fiber speed of the Gig port once you connect the fiber. The interface name will not change as you can see below it shows as a TenGigabit interface but as you can see below the speed is auto detected as 1Gig. Another word is you connect a 1Gig fiber it will run at 1 Gig speed  or if you connect a 10Gig fiber it will run at 10Gig speed.
I hope this helps a little.
sh int tenGigabitEthernet 6/1
TenGigabitEthernet6/1 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet Port, address is 4c00.82f0.b9c4 (bia 4c00.82f0.b9c4)
  Description: Trunk connection to nyc_wfcdis2rt3a gi2/29
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX
  input flow-control is on, output flow-control is off
  Last input 00:00:07, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute input rate 129000 bits/sec, 53 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     333591524 packets input, 214797107961 bytes, 0 no buffer
     Received 4343461 broadcasts (4343456 multicasts) nyc-wfcacc7sst3a#sh int tenGigabitEthernet 6/1
