Cisco 4510 High CPU due to ARP Input
83881463a
Hello all,
I am facing this issue in my client.
In business hours, every 30 minutes, the CPU increases to 99%-100% due to ARP Input process. Initially, it was the ARP snoop process, but we disable "ip device tracking" functionality from all the interfaces and this problem disappear but the other one arises.
The problem is that some clients lose connectivity during this high CPU moment and it provokes that the application they are running freezes.
We have configured authentication through ISE in the interfaces, if we desconfigured it, the problem of losing connectivity is solved; but we want to keep the authentication and I can find where the problem is.
Any suggestion?
The switch is in VSS mode with Cisco 4510 sup8, version IOS-XE 03.06.07.
Thank you in advance.
Reza Sharifi
Can you post the ISE config on the switch?
Are you using an external device as your ISE server or the switch?
Hello Reza,
here is the configuration:
- Global:
aaa group server radius ISE
 server 10.10.10.1 auth-port 1812 acct-port 1813
 server 10.10.10.2 auth-port 1812 acct-port 1813
aaa authentication dot1x default group ISE
aaa authorization config-commands
aaa authorization network default group ISE
aaa authorization auth-proxy default group ISE
aaa accounting send stop-record authentication failure vrf default
aaa accounting dot1x default start-stop group ISE
aaa accounting system default start-stop group ISE
aaa server radius dynamic-author
 client 10.10.10.1 server-key 7 014224291524140E2F4B1D
 client 10.10.10.2 server-key 7 075E036100260B04191558
ip port-map http port 8080
epm logging
dot1x system-auth-control
ip http server
ip http port 8080
ip http secure-server
ip access-list extended ACL-ALLOW
 permit ip any any
snmp-server host 10.10.10.1 version 2c XXXXXXXX
snmp-server host 10.10.10.2 version 2c XXXXXXXX
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server host 10.10.10.1 auth-port 1812 acct-port 1813 key 7 XXXXXX
radius-server host 10.10.10.2 auth-port 1812 acct-port 1813 key 7 XXXXXX
radius-server timeout 2
radius-server vsa send accounting
radius-server vsa send authentication
mac address-table notification change
mac address-table notification mac-move
- Interface:
interface GigabitEthernetX/Y/Z
 switchport access vlan X
 switchport mode access
 switchport voice vlan Y
 ip device tracking maximum 0
 ip access-group ACL-ALLOW in
 logging event link-status
 logging event trunk-status
 authentication host-mode multi-domain
 authentication open
 authentication order mab dot1x
 authentication priority mab dot1x
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 authentication timer inactivity 180
 authentication violation restrict
 mab
 snmp trap mac-notification change added
 snmp trap mac-notification change removed
 auto qos voip cisco-phone
 dot1x pae authenticator
 dot1x timeout tx-period 10
 qos trust device cisco-phone
 spanning-tree portfast
 spanning-tree bpduguard enable
 service-policy input AutoQos-4.0-Cisco-Phone-Input-Policy
 service-policy output AutoQos-4.0-Output-Policy
I don't understand the question about using a external device as our ISE server. The Radius server is a Cisco ISE and the authentications go directly to it.
Hope this helps
