10-11-2007
05:33 AM
- last edited on
03-25-2019
03:57 PM
by
ciscomoderator
I have heard that slot 10 can only accept certain blades when you have fully populated chassis. I wasn't able to find any related information on CCO. Does anyone know about this? I plan to add a WS-X4448-GB-RJ45 and show mod look like this
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4516
2 2 1000BaseX (GBIC) Supervisor(standby) WS-X4516
3 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45
4 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45
5 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45
6 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45
8 48 1000BaseX (SFP) WS-X4448-GB-LX
9 48 1000BaseX (SFP) WS-X4448-GB-LX
Solved! Go to Solution.
10-11-2007 06:38 AM
From Cisco doc on the 4510R chassis
Slot 1 is reserved for the supervisor engine only, which provides switching, local and remote management, and switch-status monitoring. Slot 2 is reserved for a redundant supervisor engine only. Slots 3 through 9 are available for switching modules. When using a Supervisor Engine V, slot 10 is a flex-slot for use with the 2-port Gigabit Ethernet switching module (WS-X4302-GB) or the Access Gateway Module (WS-X4604-GWY) only. When using a Supervisor Engine V-10GE, any supported module may be used in slot 10.
Jon
10-11-2007 06:38 AM
Jon
10-11-2007 06:44 AM
Jon
Do you happen to have a URL for this?
Thanks.
10-11-2007 06:55 AM
