Cisco 4948 supported Stackable?
mueddib
Community Member
1Hello all;
I want buy Cisco Switchs.
Spec:
MAC Support: 16000
Backplane: 18Gbps
Forward: 28Gbps
VLAN's: 4000 (q-in-q support)
Jumbo Frame Supported
Supported 8000 static routing
!Supporting Stack!
Cisco 4948 supporting stackable? which product do you recommend to these criteria?
Help me please,
Ozgur
Sergey Fer
Level 7
Level 7
4948 does not support stacking. Real stacking is only in Cat3750. You might look at newer models of Cat3750X line.
Sergey Fer
Level 7
Level 7
Hello Sergey;
thanks for information but Cisco 3750X is support 8000 line static routing and 16000 MAC based?
No, unfortunately not. 3750X and 3750E are for now topmost stackable Cisco switches, but they support only:
- 1K VLAN
- up to 12K MAC
- up to 11K routes
It also depends on what is called SDM (Switch Database Manager). For SDM = default, it supports up to 8K routes and up to 6K MACs. For more MACs or routes you need to look at Cat4500 or Cat6500, but they are modular, not stackable.
