NETFLOW
cisco.plus
Level 3
Level 3
hello
i am unable to configure netflow on 4500 catalyst switch, do i need ios upgrade and if YES then which version
I got cisco shared support on the catalyst switch. I also do have netflow collector tool
cisco WS-C4507R+E
Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(54)SG1
System image file is "bootflash:cat4500e-ipbasek9-mz.122-54.SG1.bin
cheers
CP
About Supervisors you may get info here: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/prod_qas0900aecd806d8b06.html
Q. Is NetFlow supported on the Supervisor Engine 6-E?
A. No. NetFlow is supported on Supervisor Engine 7-E and 7L-E.
About routers: No. Routers implement NF in software, so almost every router has this ability.
About 2960: do you mean Catalyst 2960? Here you can't do NF, of course.
Sergey Fer
Level 7
Level 7
NetFlow on Cat4500 is hardware-based and is available where appropriate hardware exists. Old supervisors up to Sup V do not support NetFlow by themselves. They require NetFlow Feature Card. SupV-10G supports NF by it's own. Sup 6 does not support at all. Sup 7 supports by itself. What supervisor do you have?
Hi Fer
Mate thanks for feedback. can you share document stating Sup 6 is not supported and Sup 7 is supported
Does it applies same for 2800 / 3800 series router ( hardware based or its ios based there )
is this true that netflow cannot be enabled on 2960 device
cheers
CP
