cisco 4948e
wanwa01
Guys,
need help. cisco c4948e switch  log is showing
COMPACTFLASHNOTREADY: Compact flash is not ready
Feb 24 00:28:22.338 UTC: %C4K_FLASH-4-COMPACTFLASHNOTREADY: Compact flash is not ready
checked the data sheet and is not supported. Why we get this log from the switch? is it cosmetic?
AME: "Linecard(slot 1)", DESCR: "10/100/1000BaseT (RJ45), 10GE (SFP+) Supervisor with 48 10/100/1000BASET ports and 4 10GE SFP+ port"
PID: WS-C4948E         , VID: V01  , SN: CAT1425S0NZ
NAME: "TenGigabitEthernet1/49", DESCR: "SFP-10Gbase-SR"
PID: SFP-10G-SR        , VID: V02  , SN: AGD132134ER
NAME: "TenGigabitEthernet1/50", DESCR: "1000BaseLH"
PID: Unspecified       , VID:      , SN: FNS141203YF
NAME: "TenGigabitEthernet1/51", DESCR: "1000BaseLH"
PID: Unspecified       , VID:      , SN: FNS14110R7P
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 300W )"
PID: PWR-C49E-300AC-R  , VID:      , SN: PAC14140NQY
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 300W )"
PID: PWR-C49E-300AC-R  , VID:      , SN: PAC14190L0X
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-LANBASEK9-M), Version 12.2(54)SG1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 27-Jan-11 12:28 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x1297CFEC
ROM: 12.2(44r)SG8
Hobgoblin Revision 16, Fortooine Revision 1.22
rwv-swt02 uptime is 32 weeks, 1 day, 21 hours, 17 minutes
System returned to ROM by reload
System restarted at 04:02:33 UTC Wed Jul 13 2011
System image file is "bootflash:cat4500e-lanbasek9-mz.122-54.SG1.bin"
cisco WS-C4948E (MPC8548) processor (revision 4) with 1048576K bytes of memory.
Processor board ID CAT1425S0NZ
nkarpysh
Most common reason for this error is flash being not properly setaed within slot or faulty. Can we first check or rule out those two.
Please try first to reseat flash in slot and do "dir slot0:" or "dir disk0:" and if errors will continue - try to replace it with another flash from other switch.
Please also attch "show ver" and "show mod" once steps above done to check for other possibilities.
Nik
HTH,
Niko
Guys,
correct me . Cisco 4948e is only 1RU and i cant see the compact slot on the switch. and cant locate the flash.is it internal? the data sheet mentioned only 4900M has the compact slot. no show module on the tech file.
----------------- show version ------------------
ROM: 12.2(44r)SG8
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
MPC8548 CPU at 1GHz, Cisco Catalyst 4948E
Last reset from Reload
3 Virtual Ethernet interfaces
48 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Ah right,
Compact falsh is supported only on 4900M and on E series is not:
http://www.cisco.com/en/US/partner/prod/collateral/switches/ps5718/ps6021/ps10947/data_sheet_c78-598933.html
Possibly that complains of a bootflash:. Can you try to copy any file to bootflash:
BTW please also send "show file sys" to check other  locations available.
Nik
HTH,
Niko
