Cisco 5548UP initial configuration
Frank27
I have a 5548UP , but looks like very different from the old Cisco Switches I used before.
I cannot find any initial configuration guide and I would like to use it as a basic layer 2 switch plus configuring an IP to be able to be reachable from the outside.
Any suggestion available?
Thank You.
balaji.bandi
is this single switch (then ignore vpc part, just configure as normal config)
https://networkphil.com/2015/12/07/cisco-nexus-switches-part-2-basic-configuration/
BB
balaji.bandi
BB
thanks a lot! i will give a try and report back here if i encounter problems.
For the moment, again, thank you.
when you see issue post show run of nexus device so we can guide you what we can.
BB
that guide was very useful.
As a kick-off start is important to enable inter-vlan interfaces and remember to set the exact speed for each SFP and activate first the Rapid Spanning tree for each vlan
