12-09-2021 02:20 AM
I have make a dhcp pool on a L2 switch for vlan 100. and my devices from vlan 100 are connected to a L3 switch and the L3 switch is connected to the L2 switch which is the dhcp server but when i do a dhcp request from a Pc on vlan 100 that is connected to the L3 switch the L3 switch dont froward the request to the L2 switch is just discard it. And i cant use the ip helper address command becuase it's a L2 switch that is the dhcp sever which dont work with ip address. please how can i solve this?
12-09-2021 02:22 AM
as Long as VLAN 100 passing all the way to Layer 3 Switch it should work as expected.
can you post the show run or relevant config of each switch, make sure VLAN 100 created all the way in all the switches.,
12-09-2021 02:31 AM
12-09-2021 02:37 AM
If the L2switch and L2 Switch connected with Layer3 Port-channel config, how will the Layer 2 VLAN 100 cross Layer 2 switch ?
where that Layer 2 Switch that device connected not getting IP address. ( can you post that interface configuraiton)
In this case, you need to configure VLAN 100 where the DHCP Server - that is helper address?
I take your network as below :
Layer2---Layer3---Layer2--Device ?
12-09-2021 02:41 AM
device---layer2---layer3(connected through portchannel to the dhcp server)-----layer2(this one is de dhcp server)
12-09-2021 02:44 AM
12-09-2021 02:46 AM
where is the device connected, do you have any network diagram ?
12-09-2021 02:49 AM
12-09-2021 05:45 AM
that looks like a Packet Tracer project, if it is, post the zipped project (.pkt) file here..
