Cisco 6500 ACE ARP / mac-stick enable
bdyzel123
We recently found two entries on our ACE logs constantly complaining about ip/arp collisions(%ACE-4-405001), and on further investigation we saw that these IP's related to the mac addresses no longer existed anywhere in our network.
1              5              2014-06-07 06:00:03         2014-06-08 02:00:04         WARNING            LOCAL4 ACE-CORE1:         %ACE-4-405001: Received ARP RESPONSE collision from x.x.x.x yy.yy.yy.yy.yy.yy on interface vlan5
2              4              2014-06-07 10:59:48         2014-06-08 02:59:49         WARNING            LOCAL4 ACE-CORE1:         %ACE-4-405001: Received ARP RESPONSE collision from x.x.x.x yy.yy.yy.yy.yy.yy  on interface vlan5
3              2              2014-06-07 06:59:48         2014-06-07 22:59:48         WARNING            LOCAL4 ACE-CORE1:         %ACE-4-405001: Received ARP RESPONSE collision from x.x.x.x yy.yy.yy.yy.yy.yy  on interface vlan5
4              1              2014-06-07 10:00:04         2014-06-07 10:00:04         WARNING            LOCAL4 ACE-CORE1:         %ACE-4-405001: Received ARP RESPONSE collision from x.x.x.x yy.yy.yy.yy.yy.yy  on interface vlan5
I exhausted the search for these two "ghost" ip's in our network, and finally remembered that our ACE configuration had a context we removed a few months back.
From this context we had the following configured on the interface:
interface vlan 18
  description CHAT-DMZ-FW
  bridge-group 1
  mac-sticky enable
  no shutdown
I want to confirm with you guys if anyone has seen something similar, or knows of this, but I believe the IP's learned mac addresses got "sticky" on the ACE admin context due to the mac-sticky enable command, even after we removed the context these entries persisted?
I finally used this command to remove the "ghost" IP's related to the mac addresses:
clear arp x.x.x.x no-refresh
Parvesh Paliwal
Level 3
Level 3
Dear Friend,
Also confirm if the IP addresses were reachable though  and as far as the Ghost synonym is referred, I can say there can be virtual mac-addresses, Ip addresses therein the network.
Thats it !
_
Parvesh
Hi Parvesh,
The IP address was not reachable(ping-able) at all. The IP address did show up in the arp table though.
The MAC address that it found on the ACE is the MSFC's system MAC address, so the MAC is/was valid, but not the IP.
