Cisco 6500 catos MSFC boot problem
spinning2008
Hi all,
When I am manually restarting the switch, boot loader  of the MSFC card entries are missing and going  to  rommon mode. I have to give boot command in MSFC everytime.
conf reg are same in Sp and MSFC.
I will appreciate your help
Thanks.
glen.grant
  What boot statement are you using on the msfc side ?
Thanks for reply,
I'm using this
boot bootldr bootflash:c6msfc2-boot-mz.121-4.E1
Router(boot)#show bootvar
BOOT variable = bootflash:c6msfc2-js-mz.121-4.E1.bin,12;bootflash:c6msfc2-js-mz.121-4.E1,1;
CONFIG_FILE variable does not exist
BOOTLDR variable = bootflash:c6msfc2-boot-mz.121-4.E1
Regards.
   You also need a boot statement pointing to the main IOS image and not just the bootloader image.  Where is the main MSFC image stored? Configure a boot statement pointing to the main IOS image.  Is the main image in msfc bootflash or the supervisor bootflash ? Current boot statement looks like msfc bootflash verify this . When fully booted up do a dir bootflash: and make sure the image that is specified is truly in msfc bootflash and  not in like sup-bootflash or  slot0: .
Thanks again for yor quick replay,
this is the  config of MSFC:
Router(boot)#dir bootflash:
bootflash:c6msfc2-boot-mz.121-4.E1  bootflash:c6msfc2-js-mz.121-4.E1.bin
Directory of bootflash:/
    1  -rw-     1611604   Jan 01 2003 05:11:21  c6msfc2-boot-mz.121-4.E1
    2  -rw-     7110024   Jan 01 2003 02:13:45  c6msfc2-js-mz.121-4.E1.bin
Router(boot)#show startup-config
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Router
boot system bootflash:c6msfc2-js-mz.121-4.E1.bin
boot system flash bootflash:c6msfc2-js-mz.121-4.E1
ip subnet-zero
no ip http server
line con 0
transport input none
line vty 0 4
end
Now is working with MSFC2, Can I reset this MSFC1? If a sinc with this command after reboot:
redundancy
high-availability
config-sync
Can I lose this config in MSFC2?
Regards.
