Cisco 6500 - Limit port bandwidth
a.psomas
Hello all,
I have a Cisco 6500 with IOS 12.2(33)SXJ5 .A customer have a server connected to an access port .. I want to limit this port to 60MBit full dublex. Any ideas how can i configure this ?
chrihussey
Doesn't look like you can configure CAR (committed access rate) on the 6500, however it may be dependent on different blades / IOS. Regardless I think a service policy could be applied to accomplish this. Might need some tweaking, but this should give you and idea:
class-map match-any test
  match any
policy-map TEST
  class test
   police cir 60000000 bc 11250000    conform-action transmit     exceed-action drop
interface GigabitEthernet2/7
 service-policy input TEST
 service-policy output TEST
Some bursting is allowed because if you don't it never gets to 60 Mbs. The CIR is in bits and the burst (bc) is in bytes.
Hope this helps.
chrihussey
  match any
policy-map TEST
  class test
Hope this helps.
Thanks chrihussey  I thing it works!
