Cisco 6500 Series TCP Adjust
robertsmc
I have a routed interface on a Cisco 6500 Series switch.  I am trying to find a way to adjust the tcp mss.
To date I have not yet been able to find a way to accomplish this.  Is this just not supported?
Matthew
egemen1981
Which IOS version your device using?
Here is the Version
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Sat 03-Mar-07 00:59 by tinhuang
Image text-base: 0x40101040, data-base: 0x42D98000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXF8, RELEASE SOFTWARE (fc2)
"ip tcp adjust-mss" It is supported in SXI and later releases.
It is also supported in SXJ and IOS 15.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6970/ps6017/prod_bulletin0900aecd806afd81.html
