CISCO 6500 VSS restarted.
sameermunj
hello guys,
i have a cisco 6500 switch in VSS and suddendly one of the switch in VSS got restarted... crach file got generated, please let me know if something you can find out, (software or hardware issue)
Software Version Running: ADVIPSERVICESK9-M, Version 15.1(1)SY
prinitng some chunks from the crash..
Chunk#1
%VSLP-SW2_SP-3-VSLP_LMP_FAIL_REASON: Te2/5/4: Disabled by Admin reload
%SYS-SW2_SP-3-INVMEMINT: Invalid memory action (malloc) at interrupt level
-Traceback= 40A25514z 41E259D0z 41563E5Cz 4156A740z 41629140z 4162A264z 40920404z 41618F44z 41C16058z 41675334z 41DE9A18z 40C914A4z 40C925BCz 40920404z 40C8DB1Cz 413EFD70z
*Aug 14 2013 15:45:55.575: %SYS-SW2_SP-2-MALLOCFAIL: Memory allocation of 8 bytes failed from 0x41567254, alignment 0
Pool: Processor  Free: 702372632  Cause: Interrupt level allocation
Alternate Pool: None  Free: 0  Cause: Interrupt level allocation
-Process= "<interrupt level>", ipl= 4
-Traceback= 40A10FB8z 40A25544z 41E259D0z 41563E5Cz 4156A740z 41629140z 4162A264z 40920404z 41618F44z 41C16058z 41675334z 41DE9A18z 40C914A4z 40C925BCz 40920404z 40C8DB1Cz
*Aug 14 10:15:55.575: SW2_SP: pf_ec_loadshare_set_port_load: calloc failed
Chunk#2
-Traceback= 40A24378z 41E25A48z 40C8DFD0z 40C925BCz 40920404z 40C8DB1Cz 413EFD70z 4159FB38z 415A96A8z 417408C8z 41129590z 4112A0D0z 4112A350z 412964F4z 4129388Cz 41293AC0z
*Aug 14 2013 15:45:55.599: %VSLP-SW2_SP-3-VSLP_LMP_FAIL_REASON: Te2/5/5: Disabled by Admin reload
*Aug 14 2013 15:45:55.599: %VSLP-SW2_SP-2-VSL_DOWN:   Last VSL interface Te2/5/5 went down
Chunk#3
*Aug 14 2013 15:45:55.607: %SYS-SW2_SP-3-INVMEMINT: Invalid memory action (malloc) at interrupt level
%Software-forced reload
15:46:10 UTC Wed Aug 14 2013: Breakpoint exception, CPU signal 23, PC = 0x41D24664
7 Replies 7
InayathUlla Sharieff
SAmeer,
Could you please provide me the following files;
show tech/show version
crash file completely.
Hi Inayat
Please find attached required details.
i am trying to get show tech from the device (sometimes it increses the cpu util so will not force actually)..please find below the show version output..
------------------ show version ------------------
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9-M), Version 15.1(1)SY, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 09-Oct-12 15:13 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX7, RELEASE SOFTWARE (fc1)
NDAINFA6509_SEZ-CORE uptime is 3 weeks, 2 days, 15 hours, 39 minutes
Uptime for this control processor is 2 days, 8 hours, 47 minutes
System returned to ROM by Stateful Switchover at 09:44:08 UTC Fri Apr 19 2013 (SP by reload)
System image file is "sup-bootdisk:s72033-advipservicesk9-mz.151-1.SY.bin"
Last reload reason: Admin CLI
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
Processor board ID SMC1502000V
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
72 Virtual Ethernet interfaces
486 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Hi Inayat,
Please find the attached show tech, but this is two months old ( taken on 23rd june 2013).
Hope this helps.
Hi Inayat
Please let su know if you get any clue out of it...
waiting for your input
thanks
Sameer
Sameer,
Can you also give me the ouput of show region please?
Hi Inayat
We opened TAC case with cisco and it tunrned out be CDP related Bug..
Sameer
Sameer,
Can you send me the TAC case number pleaes? If possible send me the PM.
Inayath
