Cisco 6500 VSS , VSL Link Connection Issue
John Mayer
Hello Everyone
actually i have two Cisco 6509E with two VS-S720-10G and want to run VSS on them
i do all the config same as cisco recommend, but i get somethings wrong on them, 1st. on switch2 , under "switch virtual domain" when i enter switch2, its not accepot and 2nd. non of 10G link goes up & so VSL link always down
here is my config and show commands
SWITCH#1
switch virtual domain 10
 switch mode virtual
 switch 1 priority 110
 mac-address use-virtual
redundancy
 main-cpu
  auto-sync running-config
 mode sso
interface Port-channel1
 no switchport
 no ip address
 switch virtual link 1
 mls qos trust cos
 no mls qos channel-consistency
interface TenGigabitEthernet1/5/4
 no switchport
 no ip address
 mls qos trust cos
 no cdp enable
 channel-group 1 mode on
interface TenGigabitEthernet1/5/5
 no switchport
 no ip address
 mls qos trust cos
 no cdp enable
SWITCH#2
 switch mode virtual
redundancy
 main-cpu
 mode sso
interface Port-channel2
 no switchport
 no ip address
 switch virtual link 2
 mls qos trust cos
interface TenGigabitEthernet2/5/4
 no switchport
 no ip address
 mls qos trust cos
 no cdp enable
 channel-group 2 mode on
interface TenGigabitEthernet2/5/5
 no switchport
 no ip address
 mls qos trust cos
 no cdp enable
Thank you all in advance
5 Replies 5
Reza Sharifi
What version of IOS are you running?
Can you post the output of "sh ver" from both switches?
Hello Dear Reza
at first, thanks for your replay
below you can find the Show Version of the SWITCH#1
 6500-1#sh version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(1)SY1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 01-May-13 13:16 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9-M), Version 15.1(1)SY1, RELEASE SOFTWARE (fc5)
 6500-1 uptime is 6 minutes
Uptime for this control processor is 6 minutes
System returned to ROM by  power cycle at 11:49:28 UTC Mon Nov 17 2014 (SP by power on)
System image file is "sup-bootdisk:s72033-adventerprisek9-mz.151-1.SY1.bin"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.6) with 983008K/65536K bytes of memory.
Processor board ID SMC18080014
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Virtual Ethernet interface
99 Gigabit Ethernet interfaces
5 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
as you see i use "adventerprisek9-mz.151-1.SY1" but now downgrade it to "s72033-adventerprisek9_wan-mz.122-33.SXJ2" , so nothing change and EtherChannel still not up
below are the show commands:
VSS-Sw2#show  etherchannel 2 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      N - not in use, no aggregation
        f - failed to allocate aggregator
        M - not in use, no aggregation due to minimum links not met
        m - not in use, port not aggregated due to minimum links not met
        u - unsuitable for bundling
        d - default port
        w - waiting to be aggregated
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
2      Po2(RD)          -        Te2/5/4(D)     Te2/5/5(D)
Last applied Hash Distribution Algorithm:   -
VSS-Sw2#sh etherchannel 2 port
                Ports in the group:
Port: Te2/5/4
Port state    = Down Not-in-Bndl
Channel group = 2           Mode = On      Gcchange = -
Port-channel  = null        GC   =   -         Pseudo port-channel = Po2
Port index    = 0           Load = 0x00        Protocol =    -
Age of the port in the current state: 0d:00h:00m:00s
Port: Te2/5/5
Ok, does the second switch have the same exact IOS?
under Portchannel  1 and 2 can you issue "shut" and than " no shut" and test again?
both of them have the same IOS, but in little difference that i think not Important SWITCH1 use sup-boot-disk and SWITCH2 user Disk0.
i also try shut and no shut at any time, and nothing happened yet
i think about something dummy and change the Fiber Optic Patch Cord ;)
at end there only one thing i should share with you: do i need to do anything for enabling 10G interfaces on SUP, as you know they ate jsut use for VSS , so it not possible to use them
Ok the first thing we need to know is if the physical interfaces are up and running.
If they are not than you need to fix that first before moving on and configuring VSL link.
So, what is the output of "sh ip int brief te1/5/4, 5 2/5/4 and 5?
if these links are down, then you have physical layer problems and need to troubleshot the fiber cable and optics.
BTW, you don't need to enable the interfaces for 10gig.  For these interfaces 10gig is default.
