Cisco 6500vss high cpu utilization process 'ios-base'
vaib7av.shirkul
Hi All,  we are using Cisco 6509-E VSS mode [12.2(33)SXI] ipbase image and facing high cpu utilization. In show process cpu output it is showing some "ios-base" process consuming cpu.  I attached show cpu output, thanks in advance,
Reza Sharifi
Your CPU ranges from 20 to 34%, which is not very unusual for 6500 with VSS. Also, if you are running a modular code, the CPU utilization is usually higher than with non-modular code.
