Cisco 6506-e Fan tray error
teymur azimov
Hi dears
Our company buy new Cisco 6506_e series switch. When i turn on first time then i see this fan error and i did some show command:
Router#show power
system power redundancy mode = redundant
system power total =     3795.12 Watts (90.36 Amps @ 42V)
system power used =      1621.20 Watts (38.60 Amps @ 42V)
system power available = 2173.92 Watts (51.76 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6506-E-FAN      140.70  3.35  failed
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6824-SFP        204.54  4.87   204.54  4.87  on    on
2    WS-X6848-GE-TX      404.88  9.64   404.88  9.64  on    on
5    VS-SUP2T-10G        435.54 10.37   435.54 10.37  on    on
6    (Redundant Sup)       -     -      435.54 10.37  -     -
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   7266.00 Watts (173.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              1621.20 Watts (38.60 Amps @ 42V)
system auxiliary power used =            0 Watt
Router#show environment cooling
fan-tray 1:
  fan-tray 1 type: WS-C6506-E-FAN
  fan-tray 1 mode: High-power
  fan-tray 1 fan-fail: failed
chassis per slot cooling capacity: 94 cfm
ambient temperature: < 55C
  module 1 cooling requirement: 70 cfm
  module 2 cooling requirement: 70 cfm
  module 5 cooling requirement: 84 cfm
Router#sh environment status
backplane: operating clock count: 2
  operating VTT count: 3
  operating fan count: 1
fan-tray 1:
VTT 1:
  VTT 1 OK: OK
  VTT 1 outlet temperature: 27C
VTT 2:
  VTT 2 OK: OK
  VTT 2 outlet temperature: 24C
VTT 3:
  VTT 3 OK: OK
  VTT 3 outlet temperature: 22C
clock 1:
  clock 1 OK: OK, clock 1 clock-inuse: in-use
clock 2:
  clock 2 OK: OK, clock 2 clock-inuse: not-in-use
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC high
  power-supply 1 incompatible with fan: OK
  power-supply 1 power-output-fail: OK
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC high
  power-supply 2 incompatible with fan: OK
  power-supply 2 power-output-fail: OK
module 1:
  module 1 power-output-fail: OK
  module 1 outlet temperature: 25C
  module 1 inlet temperature: 23C
  module 1 device-1 temperature: 21C
  module 1 device-2 temperature: 26C
  module 1 EARL outlet temperature: 28C
  module 1 EARL inlet temperature: 23C
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 27C
  module 2 inlet temperature: 21C
  module 2 EARL outlet temperature: 28C
  module 2 EARL inlet temperature: 22C
module 5:
  module 5 power-output-fail: OK
  module 5 outlet temperature: 34C
  module 5 inlet temperature: 21C
  module 5 device-1 temperature: 29C
  module 5 device-2 temperature: 31C
  module 5 asic-1 temperature: 50C
  module 5 asic-2 temperature: 35C
  module 5 asic-4 temperature: 51C
  module 5 asic-5 temperature: 45C
  module 5 asic-7 temperature: 45C
  module 5 asic-8 temperature: 54C
  module 5 RP outlet temperature: 29C
  module 5 RP inlet temperature: 25C
  module 5 RP device-1 temperature: 42C
  module 5 EARL outlet temperature: 29C
  module 5 EARL inlet temperature: 22C
  module 5 EARL device-1 temperature: 52C
  module 5 EARL device-2 temperature: 53C--
at the begining :
Oct  7 10:47:54.299: %C6KPWR-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
*Oct  7 10:47:55.347: %C6KENV-4-FANHPMODE: Fan-tray 1 is operating in high power mode
*Oct  7 10:48:00.835: %FABRIC-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
*Oct  7 10:48:03.211: %C6KENV-4-FANTRAYFAILED: fan tray 1 failed
1.First i think that this is a high power problem. we must be decrease the power? am i rigth?
2. As you see power mode is High-power.
i know that e series default power mode is restricted but here is high power.
is it possbly i chanege the power mode to restricted mode? if yes, which command i must be type?
please help me.
thanks.
Hello Teymur,
the high power mode, at least for me, is normal mode in our DataCenter's.
I don't believe that your problem is the power mode but yes that your fan is broken (stopped).
I recommend you to open RMA directly for that FAN.
Here you have an output from our Catalyst 6500 (in VSS),and they are working perfectly:
show power
system power total =     5771.64 Watts (137.42 Amps @ 42V)
system power used =      3096.66 Watts (73.73 Amps @ 42V)
system power available = 2674.98 Watts (63.69 Amps @ 42V)
1    WS-CAC-6000W       5771.64 137.42 OK     OK     on
2    WS-CAC-6000W       5771.64 137.42 OK     OK     on
                        Pwr-Allocated  Oper
1    WS-C6509-E-FAN      210.00  5.00  OK
1    WS-X6724-SFP        125.16  2.98   125.16  2.98  on    on
2    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
3    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
4    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
5    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
6    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
7    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
8    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
9    WS-X6716-10GE       457.80 10.90   457.80 10.90  on    on
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system primary power used =              3096.66 Watts (73.73 Amps @ 42V)
switch 1 fan-tray 1:
  switch 1 fan-tray 1 type: WS-C6509-E-FAN
  switch 1 fan-tray 1 mode: High-power
  switch 1 fan-tray 1 fan-fail: OK
  switch 1 module 1 cooling requirement: 70 cfm
  switch 1 module 2 cooling requirement: 70 cfm
  switch 1 module 3 cooling requirement: 70 cfm
  switch 1 module 4 cooling requirement: 70 cfm
  switch 1 module 5 cooling requirement: 35 cfm
  switch 1 module 6 cooling requirement: 35 cfm
  switch 1 module 7 cooling requirement: 70 cfm
  switch 1 module 8 cooling requirement: 70 cfm
  switch 1 module 9 cooling requirement: 84 cfm
Best Regards.
