cisco 6509 booting problem - help plz .
Engr.Night
dear all , good day to you .
please i have a problem in my cisco core switch 6509
(( I have two core switches 6509 connected to each other – redundancy – stp ) , and now I am working only using core switch no. 1 .
the problem history :
- the switch not responding and all the indicators , RED .
- I WENT TO THE CONSOLE , AND I MADE @ RESET , FROM THE BUTTON IN THE FRONT OF THE SWITCH ''
AND THE SWITCH WENT TO ROMMON MODE
rommon 1>
here , i did not know what to do '' the first time i had ever seen that rommon .
so , i did the following after searching on the internet to solve the problem
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################################################################################################################################# [OK]
running startup....
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) s72033_sp Software (s72033_sp-IPSERVICES_WAN-VM), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Thu 14-Feb-08 06:21 by kellythw
Image text-base: 0x01020150, data-base: 0x01021000
Created ION FileSystem for disk0, disk1
00:00:30: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:30: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:35: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:31: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
Firmware compiled 11-Jan-08 17:14 by integ Build [100]
00:00:35: %OIR-SP-6-CONSOLE: Changing console ownership to route processor
System Bo otstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Technical Sup port: ht tp:/ /w w w.cisco.com/techsup port
Copyright (c) 20 05 by cisco Systems, Inc.
Testing lower main memory - data equals ad dres s
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bs s
Reading monitor variables from NVRAM
Reset reason 0xffff.
Enabling interrupts
Initializing TLB
Initializing r7k_L2_cache
Initializing cache
Initializing r7k_L2_cache done
Initializing r7k_L3_cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
rommon 1 > dir bootflash:
         File size           Checksum   File name
    356882 bytes (0x57212)    0x26367d68    crashinfo_ios-base-20090301-042708
    384916 bytes (0x5df94)    0xe44f96ad    crashinfo_ios-base-20090301-101942
    356662 bytes (0x57136)    0x5eae249a    crashinfo_ios-base-20090301-224443
    379446 bytes (0x5ca36)    0x3f0b40cc    crashinfo_ios-base-20090302-091613
    391670 bytes (0x5f9f6)    0xfc66a1d3    crashinfo_ios-base-20090705-121033
    267688 bytes (0x415a8)    0x5b0d0d39    crashinfo_ios-base-20090705-202503 (deleted)
rommon 2 > dir dev
Devices in device table:
        id  name
bootflash:  boot flash
    slot0:  PCMCIA slot 0
    eprom:  eprom
rommon 3 > dir slot0
bad device name (Device not supported)
usage: dir <device>
rommon 4 >
System Bo otstrap, Version 8.5(2)
Copyright (c) 19 94-20 07 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
SLOTCACHE=cards;
BOOT=
CRASHINFO=bootflash:debuginfo_20080804-121518
RET_2_RTS=09:23:29 UTC Sun Oct 31 2010
TYFIB_BLOCK_ALLOC=
BSI=0
RET_2_RCALTS=
ACL_DENY=0
?=1
PF_REDUN_CRASH_COUNT=2
rommon 2 > boot bootflash:s72033-ipservices_wan-vz.122-18.SXF13.bin
Loading image, please wait ...
Initializing ATA monitor library...
running startup....
           cisco Systems, Inc.
Clearing bs s
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
rommon 1 > ?
alias               set and display aliases command
break               set/show/clear the breakpoint
confreg             configuration register utility
cont                continue executing a downloaded image
dev                 list the device table
dir                 list files in file system
dis                 disassemble instruction stream
frame               print out a selected stack frame
help                monitor builtin command help
history             monitor command history
meminfo             main memory information
repeat              repeat a monitor command
reset               system reset
set                 show all monitor variables
unalias             unset an alias
boot                boot up an external process
context             display the context of a loaded image
stack               produce a stack trace
sync                write monitor environment to NVRAM
sysret              print out info from last system return
tscope              timer scope loop
sleep               sleep command
xmodem              x/y modem download
rommon 2 > set
PS1=rommon ! >
CONFREG=0xe500
?=0
rommon 3 > confreg
           Configuration Summary
   (Virtual Configuration Register: 0xe500)
enabled are:
[ 0 ] diagnostic mode
[ 1 ] use net in IP bcast address
[ 2 ] load rom after netboot fails
[ 3 ] use all zero broadcast
[ 4 ] console baud: 9600
boot: ...... the ROM Monitor
do you wish to change the configuration? y/n  [n]:  y
disable "diagnostic mode"? y/n  [n]:
disable "use net in IP bcast address"? y/n  [n]:
disable "load rom after netboot fails"? y/n  [n]:
disable "use all zero broadcast"? y/n  [n]:
enable  "break/abort has effect"? y/n  [n]:
enable  "ignore system config info"? y/n  [n]:
change console baud rate? y/n  [n]:
change the boot characteristics? y/n  [n]:
enabled are:
rommon 4 > confreg 2102
You must reset or power cycle for new config to take effect
rommon 5 > reset
Download Start
Download Completed! Booting the image.
Self decompressing the image : ################################################################################## [OK]
running startup....
rommon 1 > boot
string is bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin
running startup....
           cisco Systems, Inc.
Active crashed three times, disabling auto-boot and dropping to rommon
Crashdump : 10:34:46.932  Sun Nov 13 2011 : ios-base : (PID=12312, TID=4) : -Traceback=(s72033-ipservices_wan-9-dso-b.so+0xF89CC) ([32:0]+0xFD080) ([32:0]+0xE6F50) ([32:0]+0xE1D5C) ([22:-9]4+0x13DE4) ([32:0]+0x13DBC)
crashdump called (with pause = 0 sec)
Buffered messages:
Queued messages:
%ALIGN-1-FATAL: Illegal access to a low address
addr=0x0, pc=0x73E98D14, ra=0x73E98D10, sp=0x2CBD7E0
SLOT0:00:00:31: %DUMPER-3-PROCINFO: pid = 12312: (sbin/ios-base), terminated due to signal SIGSEGV, Segmentation violation (Address not mapped)
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:             zero     at       v0       v1
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:   R0   00000000  793FF6E8  00000000
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:             t8       t9       k0       k1
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:   R24  02CBD6E0  732D4BB4  00000000  00000000
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:             gp       sp       s8       ra
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:   R28  7A57C560  02CBD7E0  00000000  73E98D10
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:             sr       lo       hi       bad
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:   R32  1000FC63  00000000  00000001  00000000
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:             cause    pc       epc
SLOT0:00:00:31: %DUMPER-3-REGISTERS_INFO: 12312:   R36  0080000C  73E98D14  00000000
SLOT0:00:00:31: %DUMPER-3-TRACE_BACK_INFO: 12312: (s72033-ipservices_wan-7-dso-b.so+0x442D14) (s72033-ipservices_wan-9-dso-b.so+0xF89CC) (s72033-ipservices_wan-9-dso-b.so+0xFD080) (s72033-ipservices_wan-9-dso-b.so+0xE6F50) (s72033-ipservices_wan-9-dso-b.so+0xE1D5C) (s72033-ipservices_wan-4-dso-b.so+0x13DE4) (s72033-ipservices_wan-4-dso-b.so+0x13DBC)
SLOT0:00:00:34: %DUMPER-6-BAD_PATH: 12312: Choice 1 either not configured or bad path. Trying next choice.
SLOT0:00:00:34: %DUMPER-6-BAD_PATH: 12312: Choice 2 either not configured or bad path. Trying next choice.
SLOT0:00:00:34: %DUMPER-6-BAD_PATH: 12312: Choice 3 either not configured or bad path. Trying next choice.
SLOT0:00:00:34: %DUMPER-3-DUMP_FAILURE: 12312: Core dump failed: Could not create core
SLOT0:00:00:35: %DUMPER-3-CRASHINFO_BAD_PATH: 12312: Crashinfo file creation for the path bootflash:/crashinfo_ios-base-20111113-103447 failed.
SLOT0:00:00:35: %SYSMGR-3-ABNORMTERM: ios-base:1 (jid 73) abnormally terminated, restart disabled
SLOT0:00:00:35: %SYSMGR-6-ERROR_EOK: ios-base:1 (jid 73) mandatory process exited, rebooting
Directory of bootflash:
2      100334736 -rw-     s72033-ipservices_wan-vz.122-18.SXF13.bin
12250    49560     -rw-     debuginfo_20080804-121518
17739    376822    -rw-     crashinfo_ios-base-20090609-225848
17785    371212    -rw-     crashinfo_ios-base-20090610-025924
rommon 2 > dit r slot0:
bad device name (device not supported)
usage: dir <device>
rommon 3 > dir disk0:
PCMCIA disk0: device is not initialized
open: read error...requested 0x4 bytes, got 0x0
trouble reading device magic number
dir: cannot open device "disk0:"
rommon 4 > dev
        id  name
bootdisk:  boot disk
    disk0:  PCMCIA Disk 0
    disk1:  PCMCIA Disk 1
    eprom:  eprom
rommon 5 > dir bootdisk:
Directory of bootdisk:
12257    371200    -rw-     crashinfo_ios-base-20090301-042708
rommon 6 > confreg 0x2102
rommon 7 > reset
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
running startup....
           cisco Systems, Inc.
Download Start
running startup....
           cisco Systems, Inc.
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICES_WAN-VM), Version 12.2(18)SXF13, RELEASE SOFTWARE (fc1)
Compiled Thu 14-Feb-08 06:05 by kellythw
cisco WS-C6509-E (R7000) processor (revision 1.4) with 491520K/32768K bytes of memory.
Processor board ID SMC120500AJ
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
1 Virtual Ethernet/IEEE 802.3 interface
144 FastEthernet/IEEE 802.3 interfaces
40 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Press RETURN to get started!
00:00:47: curr is 0x0
00:00:47: RP: Currently running ROMMON from S (Gold) region
00:01:08: %SYS-5-CONFIG_I: Configured from memory by console
00:01:10: %SYS-5-RESTART: System restarted --
00:00:35: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:02:12: SP: SP: Currently running ROMMON from S (Gold) region
00:02:27: %SYS-SP-5-RESTART: System restarted --
User Access Verification
Password:
00:02:28: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:02:28: %C6KPWR-SP-4-PSOK: power supply 1 turned on.
00:02:28: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:02:28: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:02:28: %C6KPWR-SP-4-PSREDUNDANTBOTHSUPPLY: in power-redundancy mode, system is operating on both power supplies.
00:02:38: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 6.
00:02:38: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 6 became active.
00:02:39: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
% Password:  timeout expired!
Password:
00:03:01: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
00:03:03: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
After that , the switch gose in the config mode
CORE2>
00:01:50: %SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
hostname CORE2
enable secret .
no aaa new-model
firewall module 7 vlan-group
firewall vlan-group
intrusion-detection module 8 management-port access-vlan
intrusion-detection module 8 data-port 1 access-vlan
intrusion-detection module 8 data-port 2 access-vlan
ip subnet-zero
no ip domain-lookup
no mls flow ip
no mls acl tcam share-global
mls ip multicast flow-stat-timer 9
mls cef error action freeze
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
redundancy
mode sso
main-cpu
  auto-sync running-config
after that , I desired to TEST the core 2 by switching off the core switch no. one , BUT ,I notice that the core2 made RELOAD immediately , and takes some minutes to return back , BUT , the network still not working when core 2 working a lone .
I checked the booting of core2 by issuing :
CORE2#  sh boot
BOOT variable = sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin,12;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby is not present.
After that , I turned  ON core switch no . 1  , NOW BOTH CORE 1 AND CORE 2 ARE ON , AND I NOTICE THAT THE WHOLE NETWORK IS DOWN AND NOT WORKING .
WHEN I TURED OFF THE CORE SWITCH NO 2 , THE SYSTEM GOES UP AND WORK ( ONLY WHEN CORE 1 WORK A LONE , NOT LIKE OLD TIMES I WAS WORKING ON BOTH  ))
I ISSUED THE FOLLOWING ON CORE 1
sh verboot
BOOT variable =
CONFIG_FILE variable =
BOOTLDR variable =
CORE1#sh ver
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR:
CORE1 uptime is 1 day, 22 hours, 7 minutes
Time since CORE1 switched to active is 1 day, 22 hours, 7 minutes
System returned to ROM by  power cycle at 12:23:56 UTC Mon Aug 4 2008 (SP by power on)
System image file is "sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin"
Processor board ID SMC120500AS
Bridging software.
4 Virtual Ethernet/IEEE 802.3 interfaces
Patching is not available since the system is not running from an installed image. To install please use the "install file" command
And also switch on core 2 and issued the following :
CORE2 BOOTING
CORE2#sh ver
BOOTLDR:
CORE2 uptime is 11 minutes
Time since CORE2 switched to active is 11 minutes
System returned to ROM by reload (SP by reload)
Bridging software.
--More--         TN3270 Emulation software.
CORE2#  sh boot
Could any one help me pleeeeeeeease ?
Thanks in advance .
Night .
19 Replies 19
Reza Sharifi
It appear that your IOS is crashing due to memory issues. You should download a newer version of IOS and load it to the sup.  What model sup do you have?
Engr.Night
hi Reza ,
thanks for replaying .
and i believe that you are asking about this :
please look again to the post , and i beleive you will find all answers you need .
thanks .
Night .
Are you sure???
I've never seen a Sup720 with PCMCIA card.  Only the Sup1 and Sup2 have PCMCIA card.
hi leolaohoo ,
please note , that i do not enough eperiance about troubleshooting cisco 6509 , but please check the above details , and also check the following :
Clearing bs s
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
rommon 2 > dir dev
        id  name
    eprom:  eprom
usage: dir
rommon 4 >
rommon 1 > set
PS1=rommon ! >
SLOTCACHE=cards;
BOOT=
TYFIB_BLOCK_ALLOC=
BSI=0
RET_2_RCALTS=
thanks  alot .
Night .
If you have physcial access of the chassis, take a picture of the supervisor blade.  The model number is located on the upper left-hand corner of the blade.  The blade is normally colored light-blue on the edges.
هi will do that tomrrow morning .
but could you pleade tell me what kind of problem i may have ?
and the first core switch core1 ( working good ) and its booting is :
core1
sh boot
BOOT variable =
BOOTLDR variable =
sh boot
BOOT variable =
BOOTLDR variable =
and core2 ( have the problem ) its booting is :
CORE2#  sh boot
why we have that difference between them ?!!!
can i check the config reg in SP by issuing this command :
remote command switch sh ver   ?!!!!
thanks .
I'm not sure what the problem is.  All I can see that doesn't make sense is that your "Sup720" has a PCMCIA card.  This doesn't make sense.  I want to verify a number of angles first.
As Reza has recommended, have you tried using an updated code since SXF is a very, very old IOS version.
By the way, Reza is one of the premier 6500 contributor here.  If he can't find anything wrong with it ...
Leo,
Appreciate for the compliment.
Night,
If these 2 switches are exactly the same, can you provide "sh mod" form the good switch?
If you have a CF card, you can insert it into the good 6500 sup and copy the file into it.  Once that is copied you can put it in the bad one and see if it boots.  Before you copy the file, make sure you delete the files on the CF card and format it.
Reza Sharifi
hi ,
YES THE CORE 1 IS EXACTLY THE SAME AS CORE2
could you please translate your post by using the command ? please !!
as i told you before i am a new in trouble shooting the ios and copying IOS .
WHAT IF I DO NOT HAVE CF CARD ? FROM WHERE I CAN DOWNLOAD IOS OF CORE1 TO COPY AT CORE2 ?!!
thanks .
If you don't have a CF card, then you need to download a new IOS from Cisco's site (need a valid Smartnet contract) and use the Xmodem to load it.  Xmodem is very slow, it will probably take all night to load a 140Mb file.
I don't have a 6500 in front of me to use ? mark.
from the good switch,
What is the output of sh mod, dir, and sh ver?
tomorrow i will do all the required command and i will past here .
thanks Raza .
Dear all , per your requist plz find below the sh commands results  for both CORE1 ( WORKING ) ANDN CORE2 ( HAVE THE PROBLEM ) :
CORE2#   sh bootvar
CORE2#remote command switch sh bootvar
BOOT variable = bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin,12;
CORE2#sh ver
BOOTLDR:
CORE2 uptime is 6 minutes
Time since CORE2 switched to active is 6 minutes
System returned to ROM by  power cycle (SP by power on)
Bridging software.
CORE2# sh mod
Mod Ports Card Type                              Model              Serial No.
  1   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210HTDB
  2   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210HTCC
  3   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210J0AS
  4   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1212K1RR
  6    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1212JVAX
  7    6  Firewall Module                        WS-SVC-FWM-1       SAD121504XG
  8    8  Intrusion Detection System             WS-SVC-IDSM-2      SAD121504N2
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001f.9e3e.e4e0 to 001f.9e3e.e50f   3.2   8.3(1)       8.5(0.46)RFW Ok
  2  001f.6cc3.b890 to 001f.6cc3.b8bf   3.2   8.3(1)       8.5(0.46)RFW Ok
  3  001f.9e3f.0080 to 001f.9e3f.00af   3.2   8.3(1)       8.5(0.46)RFW Ok
  4  001f.9e96.86f8 to 001f.9e96.870f   3.1   12.2(18r)S1  12.2(18)SXF1 Ok
  6  001c.5869.6cf0 to 001c.5869.6cf3   5.6   8.5(2)       12.2(18)SXF1 Ok
  7  001f.9e82.2318 to 001f.9e82.231f   4.2   7.2(1)       3.2(6)       Ok
  8  001f.9e1b.0b1c to 001f.9e1b.0b23   6.3   7.2(1)       6.1(1)E1     Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1210HVGN  1.8    Ok
  2  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1210HVG2  1.8    Ok
  3  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1210J0DS  1.8    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1212K1KK  4.0    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3B       SAL1211JBXN  2.3    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL1212JRJ3  3.1    Ok
  8  IDS 2 accelerator board     WS-SVC-IDSUPG      ADBG7310017  2.5    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  6  Pass
  7  Pass
  8  Pass
sh run .... plz note the bootsystem:::::::::
hostname CORE2
boot system sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin
no aaa new-model
CORE2#dir
%Error opening disk0:/ (No such device)
CORE1
CORE1#dir
CORE1#sh ver
BOOTLDR:
CORE1 uptime is 5 days, 23 hours, 26 minutes
Time since CORE1 switched to active is 5 days, 23 hours, 26 minutes
Bridging software.
CORE1#sh mod
  1   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210J09S
  2   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210HTCN
  3   48  48-port 10/100 mb RJ45                 WS-X6148-45AF      SAL1210HTDG
  4   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1212K1Q1
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1212JVD1
  7    6  Firewall Module                        WS-SVC-FWM-1       SAD1214084Z
  8    8  Intrusion Detection System             WS-SVC-IDSM-2      SAD121504P2
  1  001f.9e3e.fdb0 to 001f.9e3e.fddf   3.2   8.3(1)       8.5(0.46)RFW Ok
  2  001f.6cc3.b9e0 to 001f.6cc3.ba0f   3.2   8.3(1)       8.5(0.46)RFW Ok
  3  001f.6cc3.b8f0 to 001f.6cc3.b91f   3.2   8.3(1)       8.5(0.46)RFW Ok
  4  001f.9e96.8338 to 001f.9e96.834f   3.1   12.2(18r)S1  12.2(18)SXF1 Ok
  5  0016.46f9.9b30 to 0016.46f9.9b33   5.6   8.5(2)       12.2(18)SXF1 Ok
  7  001f.9e81.f39a to 001f.9e81.f3a1   4.2   7.2(1)       3.2(6)       Ok
  8  001f.9e1b.0cd4 to 001f.9e1b.0cdb   6.3   7.2(1)       6.0(2)E1     Ok
  1  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1210J0DV  1.8    Ok
  2  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1210HVH1  1.8    Ok
  3  IEEE Voice Daughter Card    WS-F6K-FE48-AF     SAL1207GD7A  1.8    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1213K72L  4.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1212JVX0  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL1212JR9H  3.1    Ok
  8  IDS 2 accelerator board     WS-SVC-IDSUPG      ADBG7320034  2.5    Ok
  1  Pass
  2  Pass
  3  Minor Error
  4  Pass
  5  Pass
  7  Pass
  8  Pass
CORE1# sh nvr
CORE1# sh nvram
% Invalid input detected at '^' marker.
CORE1# sh nvram                   flash
CORE1#sh boot
BOOT variable =
BOOTLDR variable =
CORE1#sh bootflash
No files on device
65536000 bytes available (0 bytes used)
CORE1#rem      emote
CORE1#remote comma
CORE1#remote command swi
CORE1#remote command switch sh
CORE1#remote command switch sh bootvar
BOOT variable =
PLZ NOTE : THAT THE SUP IS :: WS-SUP720-38
AND I FOUND NO CF FOR BOTH CORE1 AND CORE2
PLZ HELP ME I NEED IT .
THANKS .
NIGHT .
o k , i still have core1 6509 running ok , can i take the IOS from it and copy to core2 ?
if yes , could you please tell me how ??
thanks .
Must be an IOS bug then when it reported PCMCIA card.
Ok, so if you have a CF slot, then you can copy the IOS from the good supervisor card to a CF and get the bad supervisor to boot from the CF.
Firstly, you need to get a CF < 2Gb in size.  Take note that not all CF are supported to it'll have to be trial-and-error.
When insert the CF into the slot of the good supervisor engine and do the following:
1.  Format the CF:  format disk0:
2.  Copy the IOS from the good supervisor card to the CF:  copy sup-bootdisk:s72033-ipservices_wan-vz.122-18.SXF13.bin disk0:s72033-ipservices_wan-vz.122-18.SXF13.bin
3.  Once copy is complete, run a MD5 hash check just to make sure:  verify /md5 disk0:s72033-ipservices_wan-vz.122-18.SXF13.bin
4.  IF there are no errors, eject the CF and insert it into the CF slot of the bad supervisor card.
If CORE 1 is the bad supervisor card, then eject the WS-X6148-45AF (S/N:  SAL1210HTDG) blade from Slot 3.
5.  In ROMmon, enter the command:  boot disk0:s72033-ipservices_wan-vz.122-18.SXF13.bin
Hope this fixes things.
NOTE:   The IOS you are running is very, very old.  Are you sure you still want to use this version?
