Cisco 6509 Module Rebooting Itself
jmspiers2006
Hi folks,
I have a 6509 that had two different modules powercycle themselves about 18 hours apart. It could be coincidence, but I've never had it happen before so I suspect it's related. Unfortunately I haven't had any luck so far identifying a root cause, so I figured I'd post here for help. Below I've pasted the logs, diagnostic messages, module info, and switch version info. Any insight is appreciated.
Thanks!
FIRST EVENT
Sep 22 09:23:54: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Egress
Sep 22 09:23:54: %SNMP-5-MODULETRAP: Module 6 [Down] Trap
Sep 22 09:23:54: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode Changed to Egress mode (Oir event or MMLS enabled)
Sep 22 09:24:19: %C6KPWR-SP-4-DISABLED: power to module in slot 6 set off (Reset)
Sep 22 09:26:07: %DIAG-SP-6-RUN_MINIMUM: Module 6: Running Minimal Diagnostics...
Sep 22 09:26:14: %SVCLC-5-FWVTPMODE: VTP mode is set to non-transparent
Sep 22 09:26:14: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress
Sep 22 09:26:14: %MLSM-6-MMLS_MODE_CHANGE: MMLS: Replication Mode Changed to Ingress mode (Oir event or MMLS enabled)
Sep 22 09:26:14: %SNMP-5-MODULETRAP: Module 6 [Up] Trap
Sep 22 09:26:14: %DIAG-SP-6-DIAG_OK: Module 6: Passed Online Diagnostics
Sep 22 09:26:18: %OIR-SP-6-INSCARD: Card inserted in slot 6, interfaces are now online
switch#show diagnostic events module 6 | b 09/22
09/22 09:26:12.247 E  [6]    check_ether_packet [6/1]: newpak is NULL!
09/22 09:26:12.375 E  [6]    komodo_plus_lb_pc_port[6/1]: check_ether_packet f
                             ailed (err-code 0)
09/22 09:26:12.379 E  [6]    komodo_plus_lb_pc_port[6/1]: check_ether_packet f
                             ailed
09/22 09:26:12.439 E  [6]    komodo_plus_test_loopback [6/1]: PC loopback test
                              with ether type 0xA501 failed
09/22 09:26:12.455 E  [6]    komodo_plus_test_loopback : loopback_port failed
09/22 09:26:13.199 E  [6]    check_ether_packet [6/4]: newpak is NULL!
09/22 09:26:13.319 E  [6]    komodo_plus_lb_pc_port[6/4]: check_ether_packet f
                             ailed (err-code 0)
09/22 09:26:13.327 E  [6]    komodo_plus_lb_pc_port[6/4]: check_ether_packet f
                             ailed
09/22 09:26:13.383 E  [6]    komodo_plus_test_loopback [6/4]: PC loopback test
                              with ether type 0xA601 failed
09/22 09:26:14.195 I  [6]    Diagnostics Passed
SECOND EVENT
Sep 23 18:20:42: %SNMP-5-MODULETRAP: Module 7 [Down] Trap
Sep 23 18:20:42: %OIR-SP-3-PWRCYCLE: Card in module 7, is being power-cycled 'off (Reset - Module Reloaded During Download)'
Sep 23 18:20:42: %C6KPWR-SP-4-DISABLED: power to module in slot 7 set off (Reset - Module Reloaded During Download)
Sep 23 18:20:56: %OIR-SP-3-PWRCYCLE: Card in module 7, is being power-cycled 'off (Module not responding to Keep Alive polling)'
Sep 23 18:20:56: %C6KPWR-SP-4-DISABLED: power to module in slot 7 set off (Module not responding to Keep Alive polling)
Sep 23 18:25:41: %DIAG-SP-6-RUN_MINIMUM: Module 7: Running Minimal Diagnostics...
Sep 23 18:25:44: %SVCLC-5-SVCLCVTPMODE: VTP mode is set to non-transparent
Sep 23 18:25:44: %SNMP-5-MODULETRAP: Module 7 [Up] Trap
Sep 23 18:25:44: %DIAG-SP-6-DIAG_OK: Module 7: Passed Online Diagnostics
Sep 23 18:25:44: %OIR-SP-6-INSCARD: Card inserted in slot 7, interfaces are now online
switch#show diagnostic events module 7 | b 09/23
09/23 18:19:00.261 E  [7]    diag_asic_read_reg16[7/1/42]: set_get_asic_regs()
                              failed (get)
09/23 18:19:00.265 E  [7]    queryHyperionSynched[7]: diag_asic_read_reg16 fai
                             led
09/23 18:19:00.269 E  [7]    test_asic_sync[7]: queryHyperionSynched failed
09/23 18:20:46.294 E  [7]    TestAsicSync Failed
09/23 18:20:46.298 E  [7]    diag_get_current_running_test_name [7]: diag_get_
                             run_info_reg failed
09/23 18:20:46.306 E  [7]    diag_pf_const2_test_has_failed[7/-1]: reg_invoke_
                             diag_get_test_attribute_by_name failed
09/23 18:25:44.222 I  [7]    Diagnostics Passed
SWITCH INFO
switch#show module all
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1107H180
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL10382FWV
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1106GG6A
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD114102ZZ
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1105FUCK
  6    6  Firewall Module                        WS-SVC-FWM-1       SAD110203XT
  7    1  Application Control Engine Module      ACE20-MOD-K9       SAD110104KW
  8   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD115100Y7
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001a.e27a.2790 to 001a.e27a.27bf   2.5   12.2(14r)S5  12.2(33)SXI3 Ok
  2  0018.bacf.998c to 0018.bacf.99bb   2.5   12.2(14r)S5  12.2(33)SXI3 Ok
  3  001a.e2eb.6ad0 to 001a.e2eb.6aff   2.5   12.2(14r)S5  12.2(33)SXI3 Ok
  4  001d.45fd.20de to 001d.45fd.210d   2.6   12.2(14r)S5  12.2(33)SXI3 Ok
  5  0017.9444.6010 to 0017.9444.6013   5.3   8.4(2)       12.2(33)SXI3 Ok
  6  0019.e78f.5a70 to 0019.e78f.5a77   4.1   7.2(1)       3.2(1)       Ok
  7  0030.f276.145a to 0030.f276.1461   2.0   8.6(0.252-En 3.0(0)A1(4a) Ok
  8  001e.13cc.c438 to 001e.13cc.c467   2.7   12.2(14r)S5  12.2(33)SXI3 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAD110707K5  3.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1052C0SQ  3.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1051BP7Y  3.1    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAD113904FV  4.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3B       SAL1103E9VS  2.3    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL1104FB3U  2.6    Ok
  8  Centralized Forwarding Card WS-F6700-CFC       SAL1207GEYP  4.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  7  Pass
  8  Pass
switch#show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
<snip>
cisco WS-C6509-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of memory.
Processor board ID SMG1109N3BK
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
27 Virtual Ethernet interfaces
248 Gigabit Ethernet interfaces
1 Ten Gigabit Ethernet interface
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Leo Laohoo
I can't believe both of your sup cards have "failed" diagnostic events in them.
Not sure what you're getting at. The data's accurate if that's what you mean. It's a copy / paste, and it is two different modules that rebooted themselves on two different days.
Create a Cisco TAC Case.  I hope I'm wrong, but I believe your back-plane card is faulty.
I hope you are too, but I have a sneaky suspicion that you're right. I appreciate the feedback!
